 Post subject: N40P Problems
PostPosted: September 21st, 2007, 9:14
Hello all people!
I get a Maxtor 6E04L0 N40P for DR u know typical failure detect on BIOS like N40P and ERR ABRT
but this case its strange this is the log maybe u can told me some :
Im try to start with a loader from 6E03L0 same CODE and microcontroler and on utility start show me same checksum so im think could be work because its the only donnor next to a 6E04L0
ROM SA CHECKSUM E59
LOADER ROM CHECKSUM E59
strange its after load loader ROM and Overlays OK, im try to write a loader from patient, but show me error on
UBA1759 Comand 53 Code 0016 , so im try to do the SA write Test and show me
Maxtor Techno command Error Command 53 Code 0111.
Im try SA Testing & Recovery and try to read some modules and was sucess, and some one so im try to write 00 00 on the bad for example the PLIST im read some good sectors from the SA zone on the P LIST and get the P LIST Code and backup on a BIN file, so after this write 00´s to the P LIST modules, and select write to HDD; but when do this show me error and cant write nothing , so im try to write the good P LIST code , wich i was saved before, and show me the same problem.
This is the report of the SA
SA structure test
Selected family ........................... N40P
Model ..................................... Maxtor N40P
Firmware .................................. NAR6253Z
Serial ....................................
Min. cylinder ............................. 0
Max. cylinder ............................. 4294967295
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST01
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 9
HDD configuration module
Id ........................................ 1F
Header .................................... DISK
Model ..................................... Maxtor 6E040L0
Serial number ............................. E122DESE
Max LBA ................................... 78165360
Head number ............................... 1
Head map .................................. 3
SA head map ............................... 3
Model1 ............................... Maxtor 6E040L1
Max LBA .............................. 80293248
Model2 ............................... Maxtor 6E020L1
Max LBA .............................. 40718160
Model3 ............................... Maxtor 6E030L1
Max LBA .............................. 60058656
Model4 ............................... Maxtor 6E020L1
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV6À]
Checking User data adaptives
Header .................................... CR0TF`
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 352: 411: 540
2 : 412: 2854: 990
3 : 2855: 12514: 972
4 : 12515: 19231: 960
5 : 19232: 23997: 945
6 : 23998: 28051: 930
7 : 28052: 37197: 900
8 : 37198: 41320: 864
9 : 41321: 44701: 840
10 : 44702: 49261: 810
11 : 49262: 52699: 780
12 : 52700: 56498: 750
13 : 56499: 61549: 720
14 : 61550: 64779: 684
15 : 64780: 67547: 660
16 : 67548: 70992: 630
17 : 70993: 72016: 612
Checking ROM Copy
Error ..................................... UBA 19890 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 388/3/452
Checking RZTbl
Error ..................................... UBA 18646 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/288
Checking P-List
Checking G-List
Checking RZTbl-PList
Checking HLists
Error ..................................... UBA 5687 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 362/3/288
Checking security
Header .................................... SECU
User Password ............................. "********************************"
Master Password ........................... "Maxtor*INIT SECURITY TEST STEP* "
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking [DISK/PW]
Error ..................................... Wrong Module Id "93"
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. UBA 11627 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 373/3/288
Module 0F ................................. UBA 11635 Reading error : Maxtor techno command error. Command : 53. Code : 0D09 C/H/S : 373/3/297
Module 10 ................................. UBA 11636 Reading error : Maxtor techno command error. Command : 53. Code : 0D09 C/H/S : 373/3/297
Module 11 ................................. UBA 11639 Reading error : Maxtor techno command error. Command : 53. Code : 0D09 C/H/S : 373/3/299
Module 12 ................................. UBA 12559 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 375/3/139
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 ................................. Ok
Module 19 ................................. Ok
Module 1A ................................. Ok
Module 1B ................................. Ok
Module 1C ................................. Ok
Module 1D ................................. Ok
Module 1E ................................. Ok
Module 1F ................................. Ok
Module 20 ................................. Ok
Module 21 ................................. Ok
Module 22 ................................. Ok
Module 24 ................................. UBA 15257 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 380/3/139
Module 27 ................................. Ok
Module 28 ................................. UBA 15408 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 380/3/288
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F ................................. Ok
Module 30 ................................. Ok
Module 32 ................................. Ok
Module 33 ................................. UBA 5687 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 362/3/288
Module 34 ................................. UBA 19186 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 387/3/288
Module 37 ................................. Ok
Module 38 ................................. UBA 20119 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 389/3/139
Module 39 ................................. UBA 19890 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 388/3/452
Module 41 ................................. Ok
Module 42 ................................. Ok
Module 43 ................................. UBA 11638 Reading error : Maxtor techno command error. Command : 53. Code : 0D09 C/H/S : 373/3/298
Module 44 ................................. Ok
Module 45 ................................. Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 ................................. Ok
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. UBA 11640 Reading error : Maxtor techno command error. Command : 53. Code : 0D09 C/H/S : 373/3/300
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F ................................. UBA 20267 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 389/3/288
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. UBA 12020 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 374/3/140
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. UBA 17958 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 385/3/139
Module 5C ................................. UBA 17960 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 385/3/140
Module 5D ................................. Ok
Module 5E ................................. Ok
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 ................................. Ok
Module 64 ................................. Ok
Module 65 ................................. Ok
Module 66 ................................. Ok
Module 67 ................................. Ok
Module 68 ................................. UBA 11626 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 373/3/288
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 70 ................................. Ok
Module 71 ................................. Ok
Module 72 ................................. Ok
Module 73 ................................. Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 ................................. UBA 18646 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/288
Module 79 ................................. Ok
Module 7A ................................. Ok
Module 7B ................................. Ok
Module 7C ................................. Ok
Module 7D ................................. UBA 11641 Reading error : Maxtor techno command error. Command : 53. Code : 0D09 C/H/S : 373/3/301
Module 7E ................................. UBA 12018 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 374/3/140
Module 7F ................................. Ok
Module 80 ................................. Ok
Module 81 ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8D ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 92 ................................. UBA 16877 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 383/3/139
Module 94 ................................. UBA 19579 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 388/3/139
Module 95 ................................. Ok
Module 96 ................................. UBA 22426 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 393/3/288
Module 97 ................................. UBA 22278 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 393/3/139
Module 98 ................................. UBA 22817 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 394/3/139
Module 99 ................................. Ok
Module 9A ................................. Ok
Module 9B ................................. Ok
Module 9C ................................. Ok
Module 9D ................................. Ok
Module 9E ................................. Ok
Module 9F ................................. Ok
Module A0 ................................. UBA 17028 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 383/3/288
Module A2 ................................. Ok
Module A3 ................................. Ok
Module A4 ................................. UBA 14866 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 379/3/288
Module A5 ................................. Ok
Module A6 ................................. Ok
Thanks for all u help
 Post subject: Re: N40P Problems
PostPosted: September 21st, 2007, 9:36
Hi Beto,
Did you get a good backup of module 33 at your first attempt ?
If so, i would advise hotswap. Module 1E and 21 are good, so if you have a good module 33 it should work.
Best regards,
dobre
Murphy was an optimist
PostPosted: September 22nd, 2007, 9:54
Hello dobrevjester
I can get only the header from HLIST and some 2 928 bytes of the code , after this code all its DE AD DE AD im know the full list complete should be 8 192 bytes did u think could help me that
Best Regards
Sinceraly
Alberto
PostPosted: October 10th, 2007, 10:55
RZTBL defect ->Selfscan from alternate SA.
