 Post subject: Convert UDMA database to PC3K database?
PostPosted: November 12th, 2007, 8:23
sometimes we need modules stored in the UDMA database to work with the PC3K pci version.
There is no tool supplied for that; someone has made such a tool and want to share or trade it?
Best regards,
Dobre
Murphy was an optimist
 Post subject: Re: Convert UDMA database to PC3K database?
PostPosted: November 12th, 2007, 10:40
That would be really useful, but I never made that, but also would be interested.
PostPosted: November 12th, 2007, 13:03
Save needed modules to files in UDMA database, then write modules in PCI from files?
PostPosted: November 12th, 2007, 14:02
The export format of the udma and the pci version is not the same, Starling.
PC3K cannot recognize it.
Dobre
PostPosted: November 12th, 2007, 15:57
Actually, I think there is a definite need for a conversion program. The firmware itself is the same, right? I bet it would be easy to write a program that converts between PC3KISA, PC3KPCI, PC3KUDMA, and Salvation.
PostPosted: November 13th, 2007, 10:12
Exactly !
The firmware (or so called modules data) remains in a same format. And yes, it would be easy to write such a program, as currently I could make myself being able to use PCI, ISA and Salvation's firmware to use with each other. Though, UDMA still seems to be a bit far !
PostPosted: November 26th, 2007, 15:14
Dobre
I mean save to file, not export.
Just double-click on the module, and save to file with RPM extension if you really need this particular module.
PostPosted: November 29th, 2007, 13:49
Anyway I miss the option to save or import multiple files (not PCR!!, but rpm) from/to the database.
I remember in the PCI version I could import multiple selected files from a disk folder into the database, but it seem not to work in the UDMA.
This should be done by ACE i think.
No bitcoin donations :)
PostPosted: December 3rd, 2007, 8:10
Nobody has a solution yet ?
And can someone tell me what the last item is when you right-click in the right pane of the database, just under 'refresh'.
It is still in russian and i dont know the meaning of it.
Same if you right-click in the left pane, then there appears a russian word under the 'Del' item.
Can someone translate it for me too ?
Thanks in advance,
Dobre
PostPosted: December 3rd, 2007, 14:27
It says "Execute".
PostPosted: December 3rd, 2007, 14:32
Thanks Starling :)
Dobre
