HDD GURU FORUMS http://forum.hddguru.com/ |
SAFE MODE FOR WD SATA PCBA http://forum.hddguru.com/viewtopic.php?f=11&t=8154 |
Page 1 of 1 |
Author: | misioux [ December 5th, 2007, 6:51 ] |
Post subject: | SAFE MODE FOR WD SATA PCBA |
Hello, How can I do for passing the tech commands ? It's SATA controller of WD RAPTOR WD1500ADFD drive. I jumped SSC-SEL, PM2 and OPT1 -> After power on drive switched to ready status, but when I want to read ROM I can't change ROM. I read that short circuit one point with GND and it'll work. (but wich point ?) Regards Misioux |
Author: | Starling [ December 5th, 2007, 11:19 ] |
Post subject: | Re: SAFE MODE FOR WD SATA PCBA |
Do you have PC3000 UDMA? Other tools can't work with Raptors. |
Author: | misioux [ December 5th, 2007, 13:51 ] |
Hello, Yes I have, and I downloaded the last version. Regards, Misioux |
Author: | Starling [ December 6th, 2007, 16:21 ] |
Don't know. Never worked with Raptors. |
Author: | Mikippp [ December 6th, 2007, 17:54 ] |
Hi, If U want to read rom... sticky-important-topics-beginners-please-look-here-first-f16/read-write-serial-flash-on-wdc-logic-boards-t7192.html Mikippp |
Author: | Doomer [ December 6th, 2007, 18:29 ] |
Well this drive is with WDC CPU but to get ROM utility need to use Marvell-based commands BUT it could be the Acelab utility has common error in SCT commands and will not be able to get ROM from drive with WDC CPU |
Author: | misioux [ December 7th, 2007, 11:53 ] |
Hello, Thanks for your answers. I want to re-change the head map, because after modifing the first time drive click. So I want to return native configuration, and I don't know how to do without PC3000 utilities. How can I do ? Misioux |
Author: | Doomer [ December 7th, 2007, 13:55 ] |
For safe-mode on SATA WD drives you need to put 3 jumpres close to interface connector not to power connector like on PATA drives If you was able to re-write ROM the first time you will be able to re-write it in second time with the same utiliy |
Author: | Mikippp [ December 7th, 2007, 14:47 ] |
Hi, ROM size is 128kB, or more than 128kB...? In new WDC drives ROM size is 192kB PC3000 UDMA reads only first 128kB of ROM... Mikippp |
Author: | Doomer [ December 7th, 2007, 16:54 ] |
ROM size for this drive is 128KB |
Author: | misioux [ December 10th, 2007, 6:26 ] |
Hello, I jumped board has you said, but when I power ON, busy light green during 2 sec and after light off. I tried to read ROM without success. The first time I modified ROM, I start drive in Normal mode, Now when I start drive in Normal mode drive click. I used PC3000 UDMA ver 3.2.1. Regards, Misioux |
Author: | Doomer [ December 10th, 2007, 10:35 ] |
misioux wrote: Hello, I jumped board has you said, but when I power ON, busy light green during 2 sec and after light off. Yes, it supposed to be like that, it is safe mode Drive still in ready state but without some LEDs |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
