 Post subject: Error loading "open" modules on a Hitachi VLAT
PostPosted: December 18th, 2007, 11:05
Hi Friends,
Got a Hitachi HDT725025VLAT80 that had fallen on the floor.
Heads left traces on the platters.
I changed heads, and now the drive goes quickly to ready state, but when i start the utility (udma) i get this:
Family work settings correction data loading from section 7250VLAT
Selected family......................... : CUSTOM
Model by ID............................. : <ID IS NOT READ>
Techno-mode key......................... : Ok
NV-RAM reading.......................... : Ok
Loading module table.................................................. : Ok
Loading the table of "open" modules................................... : Error
Error :............................................................... : Error executing loading "open" modules dir command
Loading zone allocation table......................................... : Ok
The Structure check report is as follows:
ROM ID.................................. : A40V
NV-RAM ID............................... : V5DOB42A
USAG version............................ : V5DOB42A
NV-RAM parameters
NV-RAM report
Loaded.................................. : Yes
Checksum................................ : Ok
ID...................................... : E2PR
mu-code................................. : V5DOB42A
FW Ver Code............................. : 0x2CC752C9
Heads................................... : 4
Head map................................ : 5 4 3 2 7 7
Module copy ABA modifier for SA......... : 0x1000
Base for cyl defect table............... : 16
SA top cyl delimiter.................... : 1585018747
Used module table
Report about module USAG, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Identified.............................. : Yes
FW Ver code............................. : 2CC752C9
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
: : : :(original): (sect): (sect): (byte) : RAM : : :
RSVD : 0 : B : 7FD20000 : 7FD20000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RSVD : 1 : B : 7FD21000 : 7FD20000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RSVD : F : B : 7FD60000 : 7FD20000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
USAG : 0 : B : 7FE20000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
USAG : 1 : B : 7FE21000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
USAG : F : B : 7FE60000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
PSHT : 0 : Ad : 7FE40000 : 7FE40000 : 256 : 84 : 0 : 00000C00 : No : : P-List module
PSHT : 1 : Ad : 7FE41000 : 7FE40000 : 256 : 256 : 0 : 00000C00 : Yes : Ok : P-List module
PSHT : F : Ad : 7FE61000 : 7FE40000 : 256 : 256 : 0 : 00000C00 : Yes : Ok : P-List module
RDMT : 0 : Ad : 7FE40100 : 7FE40100 : 32 : 32 : 16384 : 00020C00 : Yes : Ok : G-List module
RDMT : 1 : Ad : 7FE41100 : 7FE40100 : 32 : 32 : 16384 : 00020C00 : Yes : Ok : G-List module
RDMT : F : Ad : 7FE61100 : 7FE40100 : 32 : 32 : 16384 : 00020C00 : Yes : Ok : G-List module
RLBA : 0 : B : 7FE200E9 : 7FE200E9 : 1 : 1 : 80 : 00030380 : Yes : Ok : G-List reserves table module
RLBA : 1 : B : 7FE210E9 : 7FE200E9 : 1 : 1 : 80 : 00030380 : Yes : Ok : G-List reserves table module
RLBA : F : B : 7FE600E9 : 7FE200E9 : 1 : 1 : 80 : 00030380 : Yes : Ok : G-List reserves table module
CNSL : 0 : B : 7FE200CF : 7FE200CF : 1 : 1 : 480 : 0003C700 : Yes : Ok : HDD logical configuration module
CNSL : 1 : B : 7FE210CF : 7FE200CF : 1 : 1 : 480 : 0003C700 : Yes : Ok : HDD logical configuration module
CNSL : F : B : 7FE600CF : 7FE200CF : 1 : 1 : 480 : 0003C700 : Yes : Ok : HDD logical configuration module
RWCN : 0 : B : 7FE200D0 : 7FE200D0 : 1 : 1 : 114 : 0003CEC4 : Yes : Ok :
RWCN : 1 : B : 7FE210D0 : 7FE200D0 : 1 : 1 : 114 : 0003CEC4 : Yes : Ok :
RWCN : F : B : 7FE600D0 : 7FE200D0 : 1 : 1 : 114 : 0003CEC4 : Yes : Ok :
CHNM : 0 : B : 7FE200FA : 7FE200FA : 36 : 36 : 16864 : 00034000 : Yes : Ok :
CHNM : 1 : B : 7FE210FA : 7FE200FA : 36 : 36 : 16864 : 00034000 : Yes : Ok :
CHNM : F : B : 7FE600FA : 7FE200FA : 36 : 36 : 16864 : 00034000 : Yes : Ok :
SRVP : 0 : B : 7FE200D3 : 7FE200D3 : 2 : 2 : 624 : 00038800 : Yes : Ok :
SRVP : 1 : B : 7FE210D3 : 7FE200D3 : 2 : 2 : 624 : 00038800 : Yes : Ok :
SRVP : F : B : 7FE600D3 : 7FE200D3 : 2 : 2 : 624 : 00038800 : Yes : Ok :
SRVM : 0 : Ad : 7FE200EA : 7FE200EA : 16 : 16 : 8128 : 00038C00 : Yes : Ok : Module contains cylinder defects table
SRVM : 1 : Ad : 7FE210EA : 7FE200EA : 16 : 16 : 8128 : 00038C00 : Yes : Ok : Module contains cylinder defects table
SRVM : F : Ad : 7FE600EA : 7FE200EA : 16 : 16 : 8128 : 00038C00 : Yes : Ok : Module contains cylinder defects table
ZONE : 0 : Ad : 7FE200E1 : 7FE200E1 : 3 : 3 : 1421 : 0003BD00 : Yes : Ok : Zone allocation table module
ZONE : 1 : Ad : 7FE210E1 : 7FE200E1 : 3 : 3 : 1421 : 0003BD00 : Yes : Ok : Zone allocation table module
ZONE : F : Ad : 7FE600E1 : 7FE200E1 : 3 : 3 : 1421 : 0003BD00 : Yes : Ok : Zone allocation table module
PTRT : 0 : B : 7FE200E8 : 7FE200E8 : 1 : 1 : 480 : 0002E2B0 : Yes : Ok :
PTRT : 1 : B : 7FE210E8 : 7FE200E8 : 1 : 1 : 480 : 0002E2B0 : Yes : Ok :
PTRT : F : B : 7FE600E8 : 7FE200E8 : 1 : 1 : 480 : 0002E2B0 : Yes : Ok :
RAM0 : 0 : B : 7FE20002 : 7FE20002 : 101 : 82 : 51712 : 00050000 : No : : Code module
RAM0 : 1 : B : 7FE21002 : 7FE20002 : 101 : 101 : 51712 : 00050000 : Yes : Ok : Code module
RAM0 : F : B : 7FE60002 : 7FE20002 : 101 : 82 : 51712 : 00050000 : No : : Code module
OVR1 : 0 : B : 7FE20067 : 7FE20067 : 100 : 100 : 10240 : 0005CA00 : Yes : Ok : Code overlay module
OVR1 : 1 : B : 7FE21067 : 7FE20067 : 100 : 100 : 10240 : 0005CA00 : Yes : Ok : Code overlay module
OVR1 : F : B : 7FE60067 : 7FE20067 : 100 : 100 : 10240 : 0005CA00 : Yes : Ok : Code overlay module
SMRT : 0 : B : 7FE200D8 : 7FE200D8 : 1 : 1 : 512 : 0003BB00 : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE210D8 : 7FE200D8 : 1 : 1 : 512 : 0003BB00 : Yes : Ok : S.M.A.R.T. module
SMRT : F : B : 7FE600D8 : 7FE200D8 : 1 : 1 : 512 : 0003BB00 : Yes : Ok : S.M.A.R.T. module
MLBA : 0 : B : 7FE200D9 : 7FE200D9 : 1 : 1 : 302 : 0003C900 : Yes : Ok : HDD logical configuration module
MLBA : 1 : B : 7FE210D9 : 7FE200D9 : 1 : 1 : 302 : 0003C900 : Yes : Ok : HDD logical configuration module
MLBA : F : B : 7FE600D9 : 7FE200D9 : 1 : 1 : 302 : 0003C900 : Yes : Ok : HDD logical configuration module
SECI : 0 : B : 7FE200DA : 7FE200DA : 1 : 1 : 74 : 00030330 : Yes : Ok : Security information module
SECI : 1 : B : 7FE210DA : 7FE200DA : 1 : 1 : 74 : 00030330 : Yes : Ok : Security information module
SECI : F : B : 7FE600DA : 7FE200DA : 1 : 1 : 74 : 00030330 : Yes : Ok : Security information module
SRIF : 0 : B : 7FE200D5 : 7FE200D5 : 1 : 1 : 2 : 0003D2C4 : Yes : Ok : SelfScan start management module
SRIF : 1 : B : 7FE210D5 : 7FE200D5 : 1 : 1 : 2 : 0003D2C4 : Yes : Ok : SelfScan start management module
SRIF : F : B : 7FE600D5 : 7FE200D5 : 1 : 1 : 2 : 0003D2C4 : Yes : Ok : SelfScan start management module
SERL : 0 : B : 7FE200DC : 7FE200DC : 3 : 3 : 1536 : 00033600 : Yes : Ok : S.M.A.R.T. error log module
SERL : 1 : B : 7FE210DC : 7FE200DC : 3 : 3 : 1536 : 00033600 : Yes : Ok : S.M.A.R.T. error log module
SERL : F : B : 7FE600DC : 7FE200DC : 3 : 3 : 1536 : 00033600 : Yes : Ok : S.M.A.R.T. error log module
IDNT : 0 : B : 7FE200D1 : 7FE200D1 : 2 : 2 : 560 : 0002E4D0 : Yes : Ok : HDD ID data module
IDNT : 1 : B : 7FE210D1 : 7FE200D1 : 2 : 2 : 560 : 0002E4D0 : Yes : Ok : HDD ID data module
IDNT : F : B : 7FE600D1 : 7FE200D1 : 2 : 2 : 560 : 0002E4D0 : Yes : Ok : HDD ID data module
DCOT : 0 : B : 7FE200DB : 7FE200DB : 1 : 1 : 12 : 0003CB00 : Yes : Ok :
DCOT : 1 : B : 7FE210DB : 7FE200DB : 1 : 1 : 12 : 0003CB00 : Yes : Ok :
DCOT : F : B : 7FE600DB : 7FE200DB : 1 : 1 : 12 : 0003CB00 : Yes : Ok :
PTCH : 0 : B : 7FE200CB : 7FE200CB : 3 : 3 : 1237 : 0005F200 : Yes : Ok : Microcode connections table module
PTCH : 1 : B : 7FE210CB : 7FE200CB : 3 : 3 : 1237 : 0005F200 : Yes : Ok : Microcode connections table module
PTCH : F : B : 7FE600CB : 7FE200CB : 3 : 3 : 1237 : 0005F200 : Yes : Ok : Microcode connections table module
##01 : 0 : : 7FE200CE : 7FE200CE : 1 : 1 : 512 : 00000001 : Yes : Skip : Main SA track hole
##01 : 1 : : 7FE210CE : 7FE200CE : 1 : 1 : 512 : 00000001 : Yes : Skip : Main SA track hole
##01 : F : : 7FE600CE : 7FE200CE : 1 : 1 : 512 : 00000001 : Yes : Skip : Main SA track hole
##02 : 0 : : 7FE200D6 : 7FE200D6 : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##02 : 1 : : 7FE210D6 : 7FE200D6 : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##02 : F : : 7FE600D6 : 7FE200D6 : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##03 : 0 : : 7FE200DF : 7FE200DF : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##03 : 1 : : 7FE210DF : 7FE200DF : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##03 : F : : 7FE600DF : 7FE200DF : 2 : 2 : 1024 : 00000001 : Yes : Skip : Main SA track hole
##04 : 0 : : 7FE200E4 : 7FE200E4 : 4 : 4 : 2048 : 00000001 : Yes : Skip : Main SA track hole
##04 : 1 : : 7FE210E4 : 7FE200E4 : 4 : 4 : 2048 : 00000001 : Yes : Skip : Main SA track hole
##04 : F : : 7FE600E4 : 7FE200E4 : 4 : 4 : 2048 : 00000001 : Yes : Skip : Main SA track hole
PESD : : D : 7FE90000 : 7FE90000 : 128 : 0 : 65536 : 00000000 : No : : PES data log
SRST : : C : 7FEB0000 : 7FEB0000 : 255 : 31 : 130560 : 00000000 : No : : SelfScan report module
SSSC : : Dr : 7FEA0009 : 7FEA0009 : 5 : 5 : 2560 : 00000000 : Yes : Skip : SelfScan management and status module
SSCD : : Dr : 7FEA0018 : 7FEA0018 : 49 : 49 : 25088 : 00000000 : Yes : Skip : SelfScan code module
NVRC : : Dd : 7FEA01FE : 7FEA01FE : 2 : 2 : 1024 : 00000000 : Yes : Ok : NV-RAM image module
Modules checking process completed
Information about copy 0
Report about module RSVD, "SA marker"
ABA..................................... : 7FD20000
Length (sectors)........................ : 4
Module not loaded! ID = RAM0 Copy 0; Code module
Error : Module is not loaded (RAM0, Code module)
Report about module OVR1, "Code overlay module"
ABA..................................... : 7FE20067
Length (sectors)........................ : 100
mu-code................................. : A42A
Incompatible with active USAG!
Report about module IDNT, "HDD ID data module"
ABA..................................... : 7FE200D1
Firmware................................ : V5DOA42A
Model................................... : Hitachi HDT725025VLAT20
Serial.................................. : VF2100R1178GGM
Report about module CNSL, "HDD logical configuration module"
ABA..................................... : 7FE200CF
AutoReassign............................ : ON
Maximal LBA............................. : 488397167
Report about module MLBA, "HDD logical configuration module"
ABA..................................... : 7FE200D9
Capacity................................ : 302590082
Maximal LBA............................. : 24062
Report about module ZONE, "Zone allocation table module"
ABA..................................... : 7FE200E1
Length (sectors)........................ : 3
Zones count............................. : 30
# Init. LBA Init. Cyl End Cyl SPC SPT
0 : 0 : 0 : 5887 : 0 : 10
1 : 30144000 : 5888 : 11391 : 55296 : 9
2 : 57882900 : 11392 : 17663 : 49152 : 9
3 : 89190228 : 17664 : 25343 : 24576 : 9
4 : 126051828 : 25344 : 31103 : 24576 : 9
5 : 153698628 : 31104 : 34943 : 0 : 9
6 : 171392196 : 34944 : 39039 : 59392 : 8
7 : 190068816 : 39040 : 43263 : 49152 : 8
8 : 208991216 : 43264 : 47871 : 28672 : 8
9 : 228896696 : 47872 : 51711 : 28672 : 8
10 : 245484416 : 51712 : 55551 : 8192 : 8
11 : 261457776 : 55552 : 61439 : 63488 : 7
12 : 285479796 : 61440 : 66815 : 57344 : 7
13 : 307153812 : 66816 : 71295 : 32768 : 7
14 : 324356052 : 71296 : 76287 : 32768 : 7
15 : 343524372 : 76288 : 79871 : 32768 : 7
16 : 357285972 : 79872 : 83839 : 8192 : 7
17 : 371760324 : 83840 : 86911 : 2048 : 7
18 : 382818624 : 86912 : 89599 : 57344 : 6
19 : 392280384 : 89600 : 92159 : 36864 : 6
20 : 400881144 : 92160 : 96127 : 36864 : 6
21 : 414212784 : 96128 : 99839 : 36864 : 6
22 : 426684264 : 99840 : 103679 : 16384 : 6
23 : 438971464 : 103680 : 105983 : 16384 : 6
24 : 446344264 : 105984 : 108287 : 6144 : 6
25 : 453531964 : 108288 : 109951 : 0 : 6
26 : 458643772 : 109952 : 113535 : 40960 : 5
27 : 468964972 : 113536 : 116735 : 40960 : 5
28 : 478180252 : 116736 : 119295 : 40960 : 5
29 : 485552332 : 119296 : -1 : 16384 : 5
Report about module SRVM, "Module contains cylinder defects table"
ABA..................................... : 7FE200EA
Length (sectors)........................ : 16
Defects count........................... : 3152
Report about module RDMT, "G-List module"
ABA..................................... : 7FE40100
Length (sectors)........................ : 32
Header
Capacity................................ : 1900
Defects count........................... : 4
Grown................................... : 0
Data:
Candidate............................... : 4
Total hidden (cand.).................... : 4
Total hidden (grown).................... : 0
Information about copy 1
Report about module RAM0, "Code module"
ABA..................................... : 7FE20002
Length (sectors)........................ : 101
Header
Data:
Information about factroial copy
Module not loaded! ID = RSVD Copy F; SA marker
Error : Module is not loaded (RSVD, SA marker)
mu-code................................. : V5EOB4CA
Incompatible with NV-RAM!
Module not loaded! ID = RAM0 Copy F; Code module
mu-code................................. : A4CA
Firmware................................ : V5DOA4CA
Maximal LBA............................. : 490234751
Header
Defects count........................... : 0
Data:
Candidate............................... : 0
Total hidden (cand.).................... : 0
Information about common modules (Open+Spec)
I tried to rewrite the bad modules but that is not working because they are located on a damaged area.
Anyone has a suggestion how to get to the data ?
Thanks in advance,
Dobre
Murphy was an optimist
 Post subject: Re: Error loading "open" modules on a Hitachi VLAT
PostPosted: December 19th, 2007, 0:27
Hello friend!
U said the hdd reach readiness , what happend when u tried to read any sector from the begin or from the end any register error ?
Best Regards
PostPosted: December 19th, 2007, 4:37
Hi Alberto,
In DE they are all unreadable (black).
Dobre
