Forum rules
 Post subject: Can anyone tell us more about ESLIP mode ?
PostPosted: September 17th, 2013, 8:17
ESLIP mode, in Terminal on Seagate drives (only on F3 drives?)
^T puts in ESLIP mode (incl when already in ^R online mode)
The subject of ESLIP has come up a few time recently
eg
viewtopic.php?f=1&t=26068&p=184088&hilit=eslip#p184088
which seems to indicate it will record something if bad sectors are encountered
I've tried enabling it
but nothing extra seemed to be recorded
The sata data connection appears to read sectors ok (up till a bad one)
BUT was not reading the user data from the sector
(the data returned was either that from sector 0 or the last set of data that was in the buffer before eslip mode was enabled)
So anyone care to explain ESLIP mode and how to make use of it
Thanks in advance
 Post subject: Re: Can anyone tell us more about ESLIP mode ?
PostPosted: September 18th, 2013, 9:43
In this mode, the drive will respond only to ESLIP encoded packets received over the serial port interface. The ASCII diagnostic commands are not available in this mode. In this mode, the native interface (SATA, SCSI, SAS, FC) is alive. This is the default power on mode for the serial port interface unless drive supports Power-savings at power on (aka "APM ASAP").
PostPosted: September 18th, 2013, 10:32
In other words ESLIP is of no use to you unless you know the comms protocol.
PostPosted: September 18th, 2013, 14:26
Might also explain why it can be so hard to enter an initial ctrl-Z sometimes
