Forum rules
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Develop the new software for writing ROM for Seagate F3
PostPosted: June 22nd, 2020, 17:45
This is what I found:
LibCRC – Open Source CRC Library in C:
https://www.libcrc.org/
This is Python code for calculating Seagate CRCs:
https://github.com/eurecom-s3/hdd_firmware_tools
Note that the you need to reverse the endianness of the dwords before calculating the CRC.
FWIW, I have written a FreeBasic version of this code:
http://www.users.on.net/~fzabkar/temp/ST_CRC16.bas
http://www.users.on.net/~fzabkar/temp/ST_CRC16.exe
PostPosted: June 22nd, 2020, 18:42
Stealing is a relative term. We dont' live on deserted island. Linus Torvalds did not write a "new" OS - he copied all basic concepts from unix sources shared by his university. Did he steal the code? Did Bill Gates create MS-DOS from scratch, never looking on CP/M? Did Numega get windows internals used in Softice from MS? Did PC3K get HDD internals from manufacturers? Did all they steal the code?
Nothing, except 'Z1 computer', is build "from scratch"
PostPosted: June 23rd, 2020, 4:28
these are 2 different things imo.
- to look at some product and create something similar on your own
- and to peek into code samples and steal the basic implementation of a function.
the difference is the research you do and it is very easy to steal something and then pose yourself as our saviour to share your 'researches'.
Not quite ethic i think.
If you wanna build a util that can read and write ROM on F3 drives, take the time and look into the original fw, find the parts that are associated with these functions and write your code yourself, then publish it (if you want after all that).
I know exactly what it takes, it is possible, i built it too.
It is not neccessary to get docs from manufacturers to implement any function, i get no such thing either, still developed quite a few things myself.
I am not against building such tools, but this way is is not ethic and it has nothing to do with research.
I believe you have the skills to do this research yourself, and you don't need to steal info from others.
No bitcoin donations :)
PostPosted: June 24th, 2020, 1:46
the most important parts of all answers is summed up by a part of what pepe said:
"imo"
opinions and laws, and interpretations of both are a neverending source of discussion... mostly fruitless. (IMHO!)
PostPosted: June 24th, 2020, 10:17
i am just bothered by using the term 'research' for sniffing code that others developed.
Users browsing this forum: No registered users and 6 guests
