Forum rules
 Post subject: Anyone tried this guys
PostPosted: January 22nd, 2014, 3:42
I was working on small RnD (still going) which is Ident. WD Families via ROM file
Anyone tried it? or have some clues here?
thank you
:wink:
 Post subject: Re: Anyone tried this guys
PostPosted: January 22nd, 2014, 10:18
Online
yes, if you unpack ROM then you would find internal WD family number inside. FWs usually interchangeable inside one family but between different models, so Family ID is enough to identify the drive in terms of FW
https://www.linkedin.com/in/artemrubtsov/
PostPosted: January 26th, 2014, 4:30
Thank you Doomer for the info
will continue from there
PostPosted: January 27th, 2014, 4:52
Thank you Again,,,
Subject closed :wink:
