Forum rules
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3  Next
 Post subject: Any way to decode encoded read long data?
PostPosted: March 2nd, 2014, 12:56
I have a WDC WD1600BEVT-22ZCT0 in which the data returned from a read long command appears to be encoded. And by encoded I mean that a good sector that is all zeros with a normal read returns anything but zeros from a read long. Can anyone point me in the proper direction on how to possibly decode the data?
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
 Post subject: Re: Any way to decode encoded read long data?
PostPosted: March 2nd, 2014, 14:44
in no way.
usually there mussoorie buffer.
Read a few sectors and make sure.
PostPosted: March 2nd, 2014, 17:40
I am slightly confused by your response. Do you mean there is no way to decode it? Or do you mean that I should not be seeing the results that I am?
I have read several sectors of this disk using read long (22h) and read long (SCT), and both provide the same results (except the SCT provides extra ECC bytes). The data part is not even close to what is seen with a regular read. Other drives that I have will show the same data as a regular read, although I only have a few drives at my disposal.
PostPosted: March 2nd, 2014, 18:26
first 512 bytes should be all ZEROS's as you say; the rest of the bytes are for ECC. You may not be reading the correct amount of bytes or some strange circular buffer is happening
PostPosted: March 2nd, 2014, 18:34
disk with LBA48 team long reading rarely supported.
More precisely, its behavior can be controlled via technological passport.
A description of tech. passport - no.
PostPosted: March 29th, 2015, 2:00
Out of curiosity, how did you get the command to work? I'm trying to figure out how to do it.
PostPosted: March 29th, 2015, 9:58
You will need something like an ATA terminal or MHDD script to issue the Read Long unless you want to programm your own tool to send direct ATA commands to the drive.
Read here how to do it (send the commnds using HRT ATA terminal or MHDD scripts) :
http://www.hddoracle.com/viewtopic.php?f=59&t=1198
Regards.
PostPosted: March 29th, 2015, 10:01
Example using MHDD script :
; READ LONG sector 1 without retries
; see ATA standard version 3
reset
waitnbsy
regs = $00 $01 $01 $00 $00 $e0 $23
waitnbsy
%error = iserror
if %error = 1 @errlong
checkdrq
sectorsto = rdlong1.bin
goto @end
@errlong:
print "Error reading long sector 1"
@end:
PostPosted: April 3rd, 2015, 23:25
Thanks! I'll start working on it ASAP, and let you know how it goes.
PostPosted: April 4th, 2015, 1:21
OK, I ran into a snag. I'm confused on the regs. What I want to do is modify your example to hunt for different LBA sectors.
Which reg value do I change?
I'm pretty sure the first word ($00 $01) is the Action code, and the $e0 field is the log page that you write to for SCT, and the $23 is the read long command.
but which parts are the function code and the LBA address?
PostPosted: April 4th, 2015, 2:12
The script is for a READ LONG, not an SCT READ LONG.
See the ATA-3 standard.
Tutorial: Using MHDD to send ATA commands to a HDD:
http://www.hddoracle.com/viewtopic.php? ... 987&p=4307
The following example reads 1 long sector at LBA 0x543210.
regs = $00 $01 $10 $32 $54 $e0 $23
PostPosted: April 4th, 2015, 2:17
ok I did some more reading. sorry about my earlier confustion. Here's what I understand so far on the regs:
$00 Feature
$01 Count
$01 LBA 00-07
$00 LBA 08-15
$00 LBA 16-24
$e0 Device (log page is E0)
$23 Command (SCT command)
so I think i can go forward with testing. I wonder what would happen if I increasted the count to 255? would I get 255 sectors with a checksum at the end? or 255 sectors with 255 ecc checksums?
I'll poke at it and see what happens. Thanks again for your help.
PostPosted: April 4th, 2015, 11:41
Thanks so much to fzabkar and spildit! I'll let you know how it goes.
PostPosted: April 4th, 2015, 15:17
Please do share your experiences :)
Also be aware that After LBA 48 was issued, this command was declared obsolete and therefore was not implemented in LBA 48 ATA specifications.
This means that sectors beyond the LBA 28 barrier (~137 GB) cannot be read using “Read Long” .
PostPosted: April 4th, 2015, 15:38
The "E0" register is actually the Drive/Head register.
Here is the 8-bit layout:
1   LBA/CHS   1   Master/Slave   4 x Head/LBA bits
The LBA/CHS bit is a 1 in LBA mode and a 0 in CHS mode.
The Master/Slave (Drive) bit is a 0 for IDE Master and a 1 for IDE slave.
For non-data commands the head bits are ignored. Otherwise, for read/write commands the head bits are interpreted as head select bits in CHS mode (heads 0 - 15), or LBA bits 27 - 24 in 28-bit LBA mode.
For SATA drives, bits 7, 5, and 4 are ignored, AIUI.
CHS mode was superseded by LBA mode in the early 1990s. The state of the LBA/CHS bit doesn't matter for non-data commands.
The Command register (23h) corresponds to the READ LONG WITHOUT RETRIES command. SCT READ LONG is a different command.
PostPosted: April 4th, 2015, 17:46
The following script uses the SCT READ LONG command to retrieve the max LBA (0x1D1C596F) from my WD2500BB drive.
sctrdlng.bin = key sector
longsec.bin = data sector + ECC sector
sctstat.bin = SCT status
; SCT READ LONG
regs = $d6 $01 $e0 $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsfrom = sctrdlng.bin
waitnbsy
regs = $d5 $02 $e1 $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsto = longsec.bin
waitnbsy
regs = $d5 $01 $e0 $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsto = sctstat.bin
; end of script
sctrdlng.bin - read max LBA 488397167 / 0x1D1C596F (WD2500BB)
00000000  01 00 01 00 6F 59 1C 1D 00 00 00 00 00 00 00 00
00000010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
longsec.bin
00000000  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000200  1D 24 62 9B D8 F4 71 A4 80 99 F4 C6 60 A9 5E 3D
00000210  6F 01 C4 78 DA 26 9F F8 47 80 3E 0A BD D8 9D 4D
00000220  FC 65 C8 4D 56 71 F0 79 87 5F 48 DF DE 20 77 A2
00000230  EC 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000240  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000003F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
sctstat.bin
00000000  02 00 02 01 01 00 00 00 00 00 04 00 00 00 00 00
00000010  01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
00000020  00 00 00 00 00 00 00 00 D6 F3 D8 0D 00 00 00 00
00000030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000000B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000000C0  00 00 00 00 00 00 00 00 12 00 12 00 34 00 00 00
000000D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Working T13 Draft 1701DT-N - SMART Command Transport (SCT):
http://www.t13.org/Documents/UploadedDo ... r5-SCT.pdf
PostPosted: April 4th, 2015, 18:32
$00 Feature
$01 Count
$01 LBA 00-07
$00 LBA 08-15
$00 LBA 16-24
Let's try some testing on a 0-filled Quantum drive to see what happens if i increase the sector count.
Ok ...
On my test drive if i increase the "Count" register to something greater than 1 i will get ERROR and ABORT.
READING will work even if I increase the sector count.
So at least on my Quantum AS test drive the READ LONG command will just work if if read one sector at a time.
PostPosted: April 4th, 2015, 21:59
FYI the SCT READ LONG was also rendered obsolete shortly after it was proposed. Also, in the ATA specification that does list it, it states that the data may be "encoded", which is what I am seeing. I only have a few drives that support the SCT READ LONG command, but they return useless data. Some of those drives actually also support the old readlong command, but that also returns the same useless data.
I have created a couple Linux utilities that can perform both read long commands. In my ddrutility suit (can be found on sourceforge), there is the program ddru_diskutility. It will only display the data on the screen and not save it to file though. I also recently released a testing version of a new tool I am working on, HDDScriptTool (link can be found in software section on this forum). It can do both read long commands and it does save to a file.
PostPosted: April 5th, 2015, 15:55
btw, it's good to see you jump in on this one maximus. I found your ddru_diskutility and wrote a perl script that parses the hex output and can dump it to a raw data file. This allows for a full disk dump from ddru_diskutility long reads.
Unfortunately, my trouble drive is a WD drive that returns encoded data. I wonder how the WD encoding works? does it XOR with a key stored in the firmware modules or something like that?
Another idea I was thinking, is to modify the ddru_diskutility to issue vendor specific command. I know there is a vendor specific long read in the TREX manual (action code 26, function code 1) , but I dunno how to send the vendor specific command yet. I found idle3-tools, which says it can do VSC's, so I'm trying to figure out how that works. Maybe I can mix the VSC abilities of idle3-tools with ddru_diskutility, then I can feed the output to my perl script that dumps the hex data to a dd file. maybe? I'm hoping the vendor specific command decodes the data to the real values. Still need to learn C programming too. It's kinda like perl, but not.
PostPosted: April 5th, 2015, 16:12
As a matter of fact, @maximus is the original poster of this thread :)
What are you trying to do with your WD drive ? Recover data from it ? Clone it even when the normal read doesn't provide data because of some sort of Error and Abort ?
Maybe your drive have some other issues and maybe "long read" is not the correct way to use to get your data back ...
