Forum rules
 Post subject: PCB Read Channel
PostPosted: March 22nd, 2014, 15:02
Online
I am trying to find the read channel for the attached PCB. I presume the read and write channels are the ones I have marked. But both give a readout of 0V either when connected to the HDA or not. I have just tried a matching board with the same results, so I presume I have the wrong ones.
 Post subject: Re: PCB Read Channel
PostPosted: March 22nd, 2014, 15:15
ISTM that you have correctly identified the R/W differential pairs. Are you measuring 0V between each signal and ground, or 0V between each of the pairs?
PostPosted: March 22nd, 2014, 15:21
Online
Each the pairs......... How do I test against ground?
PostPosted: March 22nd, 2014, 15:28
Online
Just to clarify, I am testing the channels with a multi-meter. ie one probe on one side of the read channel pair, one probe on the other side of the read channel pair.
PostPosted: March 22nd, 2014, 15:33
The DC voltage between each side of the pair will always be zero. You need to measure the voltage between each side of the pair and ground.
PostPosted: March 22nd, 2014, 15:39
Online
Sorry to be dumb, but how do I do that. Put one probe on one side of the pair and touch the computer chassis?
PostPosted: March 22nd, 2014, 15:43
That's one way, but you could use SATA power ground or a screw hole as your ground reference.
PostPosted: March 22nd, 2014, 15:45
Online
Worked a treat, thanks Fzabkar. Learning a lot :)
