Forum rules
 Post subject: Seagate boot ROM dump
PostPosted: June 2nd, 2019, 10:15
A few years back I used some python code to dump the bootloader ROM from a seagate F3 drive using the AP and RD commands within the bootloader
It was referenced in a slide presentation by Jonas Zaddach (starting on slide 18) and written by Travis Goodspeed
http://s3.eurecom.fr/~zaddach/docs/Recon14_HDD.pdf
I can't find this script.
Can anyone help ?
 Post subject: Re: Seagate boot ROM dump
PostPosted: June 2nd, 2019, 22:39
If you can't find the Python code, it shouldn't be too difficult to write a ZOC script to do this. You could modify the ZOC script I wrote for dumping WD's bootloader.
AIUI, the command sequence is …
    AP 0<CR>
    RD<CR>
    RD<CR>
    RD<CR>
    etc
PostPosted: June 3rd, 2019, 7:02
fzabkar,
AP 0<CR>
-bootloader here. BootROM sits at 0x100000.)))
skeeter, What version BootROM you need? I've some dumps.
PostPosted: June 3rd, 2019, 7:37
E123 wrote:
fzabkar,
AP 0<CR>
I found this after I posted:
http://s3.eurecom.fr/~zaddach/docs/POC13_zaddach.pdf
Memory Range             Type
0x00000000 – 0x00008000  Code SRAM
0x00100000 – 0x00120000  ROM
0x00200000 – 0x00400000  Code DRAM
0x04000000 – 0x04004000  Data SRAM
0x40000000 – 0x50000000  IO
0x60000000 – 0x70000000  Data DRAM
PostPosted: June 3rd, 2019, 18:47
If you would like to play with WD instead, here is the boot loader from a WD20EADS (uploaded via a ZOC script):
FFFF0000-FFFF2AFF.rar [7.89 KiB]
Downloaded 122 times
@Severence and I have been able to decompress WD's ROM code (@Severence has compiled a Windows version of LZHUF for this purpose). My ROM parsing tool extracts the various code segments.
Seagate's ROM segments are compressed with a different algorithm ("CPRS").
PostPosted: June 6th, 2019, 13:59
Thanks for all the ideas, but I want to stick with seagate because it will make it much easier later when I get to the actual firmware code (having messages and diagnostics in text throughout....)
The version I have is:
SEA-3 Yeti Boot ROM 2.0 (12/06/2007)
Copyright Seagate 2007
PostPosted: June 6th, 2019, 14:25
skeeter, https://yadi.sk/d/qMVdXFEuy4zUtg
