Forum rules
 Post subject: do anyone know which CPU Hitachi-HTS543225L9A300 uses?
PostPosted: August 7th, 2019, 2:12
do anyone know which CPU HTS543225L9A300/HTS545025B9A300 or any IBM/Hitachi(M24) uses?
I have the ability to RE FW code.
Once I know the cpu/instruction set of these drives, I will start my research, and post results here.
Many people will benifit from that.
 Post subject: Re: do anyone know which CPU Hitachi-HTS543225L9A300 uses?
PostPosted: August 7th, 2019, 10:26
It's modified Mitsubishi core, no available disassembler for it, no documents either
https://www.linkedin.com/in/artemrubtsov/
PostPosted: August 7th, 2019, 11:22
hello Doomer, thanks for this valuable info.
can you tell which Mitsubishi core is close to it, part no. etc.
and where you got this info from?
disassembler is not a problem, I can create one.
PostPosted: August 7th, 2019, 11:46
I don't know which one, I know it's a 24bit core with proprietary opcodes
PostPosted: August 7th, 2019, 12:04
Dear Doomer, thanks for your quick reply.
your info is vital and it will point me in right direction.
if you have more info, please keep me updated.
PostPosted: August 8th, 2019, 2:02
Well, in the lack of documentation, I have to go the hardest way, figer out opcodes myself.
if anyone have more information about these Mitsubishi cores,
Please share
In return, I will share the results of my research here, and all of you will benifit.
thanks
PostPosted: August 8th, 2019, 19:21
Why not devote your effort to current helium models? ISTM that's where the commercial payback will be.
Otherwise, if you're just having fun, see the posts by @eaxi at hddoracle.com. He has done a lot of disassembly for the old Quantum drives, but his techniques, both software and hardware, should prove to be instructive.
PostPosted: August 9th, 2019, 8:30
Dear fzabkar,
thanks for your kind suggestion
I will definitely consider that.
PostPosted: August 9th, 2019, 8:45
OK, so I started on my own, and got some success.
like 0x2e is an opcode to read memory into a register
much like ldr r0,[r1]
its a 2 byte instruction.
