Hello everyone,
I recently bought some DELL branded SAS disks (ST2000NM0023) for my homelab, but one arrived defective. Since I also wanted to tinker around with custom firmware (in the hopes of enabling some DELL disabled features (?) I used the defective one as a sort of guinea pig. Tried flashing the DELL lod to it without removing the DELL header, big mistake. But my overall goal still stands. I want to be able to reflash these DELL disks to retail ones. I hooked up a flash programmer to a second disk and read out the flash successfully, and I'm currently trying to make sense of it all.
The firmware from the Disk seems to have two headers at the beginning, which is the first thing I don't understand. I've tried mapping out the different areas. From my understanding, the Offsets apply from the beginning of the current header, correct?
What I now want to do is to be able to use the stock Seagate LOD and use the correct bits and pieces to create a rom that will fit on the SPI flash and also work. From what I can tell this is not an F3 disk (although I am not sure as I can't find that much information on the topic), so some of the tools don't work or throw errors. I don't know if I am allowed to attack a the Seagate LOD or even the DELL ROM dump so I'll leave it until someone tells me otherwise
Is there anyone here who has done anything similar already? Just so I know. I think one of the main issues is that the drives are all currently on GE09 and I cannot find that firmware anywhere to download, so there's no way for me to compare the LOD to the actual contents of the flash. One thing I have notices is that the flash chip seems to be virtually empty after approx. 512 bytes, with only occasional blocks of zeroes.
