 Post subject: Reading Monolith SD cards without soldering - it's possible!
PostPosted: January 28th, 2018, 14:15
Hello guys,
After over 6 months of hard and intensive work including many projects, prototyping, checking different configurations we can announce officially that NEW monolith MR SD Cards adapters are officially READY !
What cards does they support ?
Ofcourse each of this can be connected beetwen devices as VNR (Rusolut), Flash Extractor (Soft Center) or PC3000 Flash v4 (Ace Laboratory) without any soldering. Each of adapter support different card size by inners and can support different pinout configuration by special socket (look to movie to see how simple we can change pinout from 1 type of pinout to second one... as examples for 2th channel). Impossible ??? ;) Check 36 minutes movie at https://youtu.be/GPHeLh1NwIw
Below photos will give more information about supported size and configurations !!!
MR39 configuration and supported card sizes as below:
MR29 configuration and supported card sizes as below:
MR40 configuration and supported card sizes as below:
MR42 configuration and supported card sizes as below:
MR35 configuration and supported card sizes as below:
Some socket photos below:
How to install adapters on different devices as VNR, FE, PC3000 Monolith board v4 or Multiboard ?
Below links:
Video of using MR40, 42, 39, 35, 29 SD adapters- https://youtu.be/GPHeLh1NwIw
MR40 SD Monolith product link - https://multi-com.eu/shrt-C8DWgvxEH
MR42 SD Monolith product link - https://multi-com.eu/shrt-pED0xFc0z
MR39 SD Monolith product link - https://multi-com.eu/shrt-IUi3QcYPI
MR35 SD Monolith product link - https://multi-com.eu/shrt-UWceLvp3
MR29 SD Monolith product link - https://multi-com.eu/shrt-3hZAWCvLu
P.S#1
Companies interested in reselling contact directly to biuro@multi-com.pl for quotes.
P.S#2
If you are looking microSD cards MR series adapter look at http://forum.hddguru.com/viewtopic.php?f=15&t=35872
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
 Post subject: Re: Reading Monolith SD cards without soldering - it's possi
PostPosted: January 28th, 2018, 15:12
Very impressive!
PostPosted: January 29th, 2018, 4:36
Nice work!
Web: https://www.day1data.de
PostPosted: January 29th, 2018, 13:52
State of the art ,
Will start reselling and using in india ASAP :mrgreen:
PostPosted: January 30th, 2018, 16:13
Very nice. Is there development for Micro SD Cards soon, too?
Hard Drive and RAID Data Recovery Specialist in Massachusetts
PostPosted: January 30th, 2018, 16:48
Labtech, did you see this: viewtopic.php?f=15&t=35872
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: January 31st, 2018, 11:19
Labtech ,
Bro They Had Released Those Before SD Cards Last Year ,check Their Youtube Channel
PostPosted: February 1st, 2018, 22:33
Yep, I missed that. My bad. Good stuff.
PostPosted: February 7th, 2018, 14:24
Thank you for all good words - since receiving a questions on PM how pinout configuration is changed in MRSD adapters just few words with explanation to make all clear since many of you don't have time to watch full video from us. So.....pinouts are changed by so called sockets which fit to adapter.
Socket for MR40 looks like:
Each of socket got name like for example
"MR40AP1" where:
MR40 - adapter model
AP1 - Alternative Pinout 1
to use them so to change pinout in less than 10 second we simply make ALL switches on adapter to OFF position and put socket into adapter. After installation in adapter it will look like this:
Similar are for other adapters like MR35:
and after installation
but there are adding some information like C1/C2 so on socket you will see
MR35AP2C1 which means
MR35 - MR35 adater type
AP2 - aleternative pinout 2
C1 - channel 1 (so reading by 8 bit bus from first channel)... if you will use C2 it will read second channel
And final answer to questions about additional sockets updates with new pinouts ???? ;) YES - we will make additional sockets if raster of card will fit.... even more: each customer who will send to us card and pinout for new configuration will receive FREE SOCKET ! So if after 6 months you will use our adapter and will find card with different pinout configuration to which you got pinout just send us this card and pinout - we will make inner for different size (if necessary) + socket for this pinout and send you for free of charge including shipment.....
Best regards,
Boguslaw Rzepka,
PostPosted: February 20th, 2018, 23:06
Hi Boguslaw ,
I have sent you a email for reselling Products in India .Kindly Check your email and respond back ,Its been a few hours since i have emailed .
PostPosted: February 21st, 2018, 12:08
Hello Amarbir,
Answered ;)))
Best regards,
Boguslaw Rzepka,
