 Post subject: Looking for WD PCB (2060-771698-002)
PostPosted: March 20th, 2020, 19:41
Hi guys
I am looking for a new PCB or repair of my PCB.
WD20EARS-00MVWB0 (2TB)
Date: 11 FEB 2011
DCM: HARNNTJMHB
DCX: 7M04V45W0
REV A
2060-771698-002
Code on the sticker:
2061-771698-802 AA
Can anyone help me please?
Got some important data on the drive. It won't start.
Shipping to Germany or Switzerland possible.
Thanks,
Ghost
 Post subject: Re: Looking for WD PCB (2060-771698-002)
PostPosted: March 20th, 2020, 20:45
http://search.store.yahoo.net/yhst-14437584971410/cgi-bin/nsearch?searchsubmit=Go&vwcatalog=yhst-14437584971410&.autodone=http?3A?2F?2Fwww.hdd-parts.com?2F&query=771698
Be aware that you will need to transfer the "ROM" at location U12. The above supplier includes a transfer in the price.
PostPosted: March 22nd, 2020, 17:52
Thanks!
Do you know any supplier in Europe?
PostPosted: March 22nd, 2020, 22:20
I don't know of any supplier who includes a ROM transfer. In any case, can you show us the other side of the board, just in case the damage is not confined to the board?
PostPosted: March 23rd, 2020, 10:50
Off course, here you are and thanks for help!
PostPosted: March 23rd, 2020, 16:22
It appears that someone has resoldered (?) the "ROM" at U12. Are you sure it hasn't been damaged?
If you have a multimeter, measure the voltages between ground and each of L1, L2 and D2 (above the SMOOTH chip). Use a screw hole as your ground reference.
Also check the TVS diodes.
TVS Diode FAQ:
PostPosted: March 25th, 2020, 11:30
TVS Diode FAQ:
Frank ,
I somehow do not see any damage to the TVS and the Zero ohms resistances ,Your observation on the ROM being soldered is correct
PostPosted: March 28th, 2020, 9:09
thank you guys for youre response. the rom is fine, i wanted to do it but stopped it, there's no damage. i will send it to the canadian supplier!
thanks
ghost
