Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Connor CFS1275A hard drive turns on makes musical sound
PostPosted: March 29th, 2015, 19:52
i know what head you are talking about
the drive head
PostPosted: December 14th, 2015, 9:30
Spildit wrote:
... your drive, ... it's not supported by the mainstream firmware data recovery tools, like PC-3000 ...
Spildit wrote:
... just want for you to know that my PC-3000 ISA supports your drive at firmware level
Your copy must be a special edition. :D
Spildit wrote:
Your "musical sound" might be ... heads hitting the limiter
Maybe a drum solo? :D Never heard anyone call hdd clicking music.
Sorry Spildit, I couldn't help noting the above.
Hi gurus,
Well, after this foreword I begin my story, maybe someone can help me (free). I have a Conner CFS420A, that behaves the same way. Spins up and down a few times then stops. It was tested with a pcb from an identical model (own pcb was physically damaged), that has no such problems. So it is definitely a motor problem in my case. I can see 3 screws on the motor cover, has anyone been successful in repairing a motor failing to reach full speed? If I remove those screws, do I get access to the spindle shaft and adding some lubricants will help? Just want to repair the drive, if possible.
By the way I have an old ST157A, same problem, not reaching full speed (led blinking 16x) is there any remedy? Thank you.
PostPosted: December 14th, 2015, 14:55
I would start by examining how a working drive behaves under fault conditions.
If you isolate the HDA from the donor PCB on the donor HDD, does the donor spin up and remain spinning?
PostPosted: December 14th, 2015, 16:40
Spildit wrote:
What is the Conner MCU ? Motorola, Uxx, Ferro or ConnerTech ?
It appears to be Motorola. U12 is a Motorola special order (SC415016AFU). According to the following discussion, these were MC68HC MCUs -- 68HC11A or 68HC11E, or possibly 68HC16 or 68HC11F.
https://community.freescale.com/thread/70871
PostPosted: December 14th, 2015, 17:59
ConnerTech is another later manufacturer which turned into Exelstore.
Motorola is what you need, although just a terminal would help.
PostPosted: December 14th, 2015, 18:03
Probably worth moving patient U15 onto your donor board and trying again. Can you upload pics of top labels from both HDDs?
PostPosted: December 14th, 2015, 18:31
Here is a photo of the complete CFS420A PCB:
http://kirpantin.vv.si/img/hdd/img_4867.jpg
http://kirpantin.vv.si/hdd.htm
http://www.computerhope.com/hdd/hdd0020.htm (specs and jumpers)
U15 looks like a ROM for U14 (SC415951FB) while U11 appears to be the ROM for U12.
PostPosted: December 14th, 2015, 21:13
It's in Russian ...
http://www.acelab.ru/dep.pc/doc.pc3000d ... cconer.pdf
U15 is probably a mask ROM:
http://web.archive.org/web/199610280301 ... m/rom.html
I expect that the pinout would be similar to these flash EEPROMs (except for WE* and Vpp):
http://www.micropik.com/PDF/28f512.pdf
http://www.romservice.ru/datashee/M28F256.PDF
http://www.futurlec.com/Datasheet/Memory/28F256.pdf
Note that the CE and OE pins may be active high:
The control pin function and active level, as well as the memory contents, are user-defined.
