Post new topic Reply to topic  [ 93 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Connor CFS1275A hard drive turns on makes musical sound
PostPosted: March 27th, 2015, 7:08
it was making musical sounds when turned on but then randomly i turned it on and spins
i dont trust my data with anyone other than myself
i have the tools and kit to carry out the work myself but was hoping if some one has a spare drive/pcb
its an old drive so i do not imagine people are using them to run windows 3.1
is there any tests i can do on the pcb or are there any components i can replace or take out to fire the drive up
PostPosted: March 27th, 2015, 7:15
Good ! Then use them, if you are so confident.
Also just for us to know, do you intend to get a pcb/drive for free and the gentle person offering you the drive will also have to pay shipping of the drive to you ?
If you are so confident that the problem is with pcb then buy one drive / pcb from that link on ebay that i've posted. You can even mail the seller and ask for a pcb with the same firmware as yours, and it's about $30 usd...
If your data is not worth any money forget about it and move on.
After all most likely it will not be a pcb issue to start with...
PostPosted: March 27th, 2015, 8:02
PostPosted: March 27th, 2015, 8:10
i am more than sure it is a pcb problem
it is an old drive and i am sure that some one will have one for free
the links you sent to me on ebay are not shipping to uk
more so customs is very high to post from us to uk
PostPosted: March 27th, 2015, 8:35
Ok. Good luck with someone sending one for free then.
Best regards and hope you get your data back.
Moving on. . . Next one !
PostPosted: March 27th, 2015, 8:58
Old drives have their own peculiar problems. Pretty certain the problem is internal rather than external! Also now it appears to spin when before it didn't has probably made a recovery more complicated and of course more expensive.
PostPosted: March 27th, 2015, 11:14
its an old drive that if anyone has such a one is not probably using so if there is any kind soul that has one and would be willing to give for free i will appreciate it
please
willing to return the kindness in any way i can
PostPosted: March 27th, 2015, 20:08
If you end up chosing TO PAY to get your data recovered and if no-one else are willing to accept the challenge, just want for you to know that my PC-3000 ISA supports your drive at firmware level :
And i can do head swap if necessary on your drive (have clean room access - expensive to use and a laminar flow workbench as well).
Regards and good luck for the free pcb.
PostPosted: March 28th, 2015, 8:39
i thanks for the advice but i am not shipping hard drive any where
the hard drive is going to be in front of my eyes all the time
PostPosted: March 28th, 2015, 9:07
Uhhh.....
Interesting :)
PostPosted: March 28th, 2015, 9:11
i can do a head swap myself if required but just need a donor drive or pcb
if it works by replacing the pcb then it will be better
PostPosted: March 28th, 2015, 9:12
What about if firmware is damaged ? How do you fix it ?
PostPosted: March 28th, 2015, 9:19
could you use ttl to diagnose
i turned on the drive just now and i can hear the head move and the platters move but then goes quite and does it again
so there is not musical sound no more
PostPosted: March 28th, 2015, 9:22
What tools are you using for firmware diagnostic ?
Do you have access to a hepa 100 clean room ?
Do you like music ?
PostPosted: March 28th, 2015, 9:25
i have access to a clean room
i am not here to disclose my knowledge
i am here for some help
PostPosted: March 28th, 2015, 9:26
So you want PCB and Hard drive for FREE but you don't want to even tell us what tools you are using ?
Is that so ?
PostPosted: March 28th, 2015, 9:30
I can get access to the tools that I require but I am here for advice and some help
If you let me know the tools I require I can see if I have them
but before that I need a PCB OR drive
PostPosted: March 28th, 2015, 9:32
Then, as you stated,
Bye.
PostPosted: March 28th, 2015, 9:34
I am not going to say I am a guru but I am just here to get some help
I will really appreciate your help
