HDD GURU FORUMS http://forum.hddguru.com/ |
NAND Flash Reader with BGA272 BGA316 adapter http://forum.hddguru.com/viewtopic.php?f=15&t=35238 |
Page 1 of 1 |
Author: | Flashguys [ April 10th, 2017, 21:47 ] |
Post subject: | NAND Flash Reader with BGA272 BGA316 adapter |
NAND Flash Reader with BGA272 BGA316 BGA224(8bit/16bit) adapter , support 4CE and 8CE chips, only used Flash Extractor,All tested ok, If you are interested please contact with SKYPE:13378120549 (49335007@qq.com) , JAKC LEE. Attachment: Attachment: Attachment: Attachment: Attachment:
Author: | Flashguys [ April 10th, 2017, 22:04 ] |
Post subject: | Re: NAND Flash Reader with BGA272 BGA316 adapter |
BGA272 8BANK Testing. Attachment: QQ图片20170411100203.png [ 2.74 KiB | Viewed 17035 times ] |
Author: | Flashguys [ April 10th, 2017, 22:35 ] |
BGA272 8CE ECC TEST OK. Attachment: QQ图片20170411103017.png [ 7.26 KiB | Viewed 17033 times ] |
Author: | Flashguys [ April 10th, 2017, 22:57 ] |
BGA224 8bit Testing. Attachment: QQ图片20170411105659.png [ 2.53 KiB | Viewed 17024 times ] |
Author: | Flashguys [ April 10th, 2017, 22:58 ] |
BGA224 8bit Tested ECC OK. Attachment: QQ图片20170411105743.png [ 5.46 KiB | Viewed 17024 times ] |
Author: | Flashguys [ April 11th, 2017, 1:03 ] |
BGA316 4CE Testing. Attachment: QQ图片20170411103750.png [ 3.02 KiB | Viewed 17009 times ] |
Author: | Flashguys [ April 11th, 2017, 1:07 ] |
Author: | Amarbir[CDR-Labs] [ April 13th, 2017, 23:57 ] |
Hi Lee , I Wanted To Know If You Sell The Actual Flash Extractor Reader Also .I Am Interested To Buy That With the Following Adapters . 1 : Basic TSOP48 Adapter X 1 Unit 2 : TLGA Adapter 18x14mm X 1 Unit 3 : BGA 152 18x14mm X 1 Unit 4 : Monolith Adapter X 10 Units PS : I Also See You Have Few Other Adapters ,I Would Not Mind Getting These Cost Also |
Author: | Flashguys [ April 14th, 2017, 22:55 ] |
Sorry we do not your adapter. Amarbir[CDR-Labs] wrote: Hi Lee ,
Author: | IC-test-socket [ May 13th, 2017, 6:34 ] |
Well done,Mr.LEE. May I know how much your socket sell? ![]() |
Author: | Flashguys [ April 18th, 2018, 0:06 ] |
UP!!UP!!UP!! |
Author: | einstein9 [ April 18th, 2018, 3:24 ] |
Anyone actually tested and tried those? |
Author: | trumanhw [ May 18th, 2018, 12:03 ] |
I don't know very much about this - and I get that this could be a completely absurd question; but is it not possible to do this with IP Box2 ? It'll read a chip, data dump, etc - from NAND. Isn't it going to the the SW that re-integrates it? The cost about $200... I just assumed you'd need the PC 3000, too. https://www.ebay.com/i/162812694908?chn ... 1852557203 |
Author: | Flashguys [ January 19th, 2019, 5:00 ] |
UP !! UP!UP! |
Author: | arvika [ January 19th, 2019, 17:39 ] |
einstein9, tested. Works ![]() |
Author: | einstein9 [ January 20th, 2019, 2:32 ] |
arvika wrote: einstein9, tested. Works ![]() Yup, perfect set added, ![]() |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
