 Post subject: in search of donor for donor drive for a WD15EARS-00MVWB0
PostPosted: September 10th, 2018, 11:36
Can anyone help me out with a donor drive for a WD15EARS-00MVWB0 with head map 0,1,2,5,6 microjog: 0: C00/3072 1: C4A/3146, 2: C52/3154, 5: C1F/3103, 6: BF9/3065 ?
Thanks!
Don Anderson
Tri-State Data Recovery
www.PhiladelphiaDriveRecovery.com
 Post subject: Re: in search of donor for donor drive for a WD15EARS-00MVWB
PostPosted: September 10th, 2018, 11:59
Thanks!
Don Anderson
http://www.PhiladelphiaDriveRecovery.com
They have few you can use...
http://www.donordrives.com/catalogsearc ... RS-00MVWB0
PostPosted: September 11th, 2018, 9:49
I've tried several WCA AZA donors with exact DCM that are within 200 MJ. Last donor I tried the patient killed head 7 which is not a good sign. I have a few more ideas to try...
Don Anderson
Certified Data Recovery Engineer
Tri-State Data Recovery & Forensics, LLC
PostPosted: September 11th, 2018, 17:43
Maybe problem is not in heads, but media damage...
http://www.pclab.com.pt facebook.com/PCLAB.Assistencia.Tecnica
ACELab partner
