 Post subject: 100406937 REV B
PostPosted: September 11th, 2018, 2:42
I'm searching such a PCB from a STM3250820AS
Maybe also the complete disk.
Anyone out there?
Model : MAXTOR STM3250820AS
Serial : 6RT*****
PN : 9DP13E-326
Firmware : 3.AAE
 Post subject: Re: 100406937 REV B
PostPosted: September 11th, 2018, 3:48
You don't have the original PCB??
ACELab partner
PostPosted: September 29th, 2018, 18:14
Do you still need this PCB ?
What is the problem with the drive ? Can you make a terminal log using the PCB that you do have ?
Does the drive spin at all ?
This is an old ST-10 so you don't even need native ROM. Should be quite easy to find a replacement PCB and most likely i have some for sell as well the main issue is that most likely the problem with your drive is not PCB related ...
