HDD GURU FORUMS
http://forum.hddguru.com/
Recover lost data
http://forum.hddguru.com/viewtopic.php?f=15&t=37825
Page 1 of 1
Author:  NickNgaruiya [ December 21st, 2018, 7:34 ]
Post subject:  Recover lost data
Hello, I have lost my hard disk data so, any option to recover data.
Author:  HaQue [ December 21st, 2018, 8:30 ]
Post subject:  Re: Recover lost data
Maybe, but you are going to need to provide at least a little more info. There are 1001 ways to lose data...
Author:  Spildit [ December 21st, 2018, 14:54 ]
Send the drive to a reputable data recovery firm ...
Author:  digisupport [ December 22nd, 2018, 6:07 ]
Yes
Author:  NickNgaruiya [ January 1st, 2019, 7:52 ]
How much cost I will be paying for recover data?
Author:  HaQue [ January 1st, 2019, 8:43 ]
$985.72
or if you fully freeze the drive yourself (see youtube) you can save $37.55
of course this is New Zealand dollars, the standard currency in Forensical Guesswork.
Author:  Spildit [ January 1st, 2019, 9:33 ]
Maybe you should start by describing what did happen to the data ?
Did the drive stop working ?
Full drive model ?
Did you erase the data yourself ? If so did you write more stuff to the drive (DO NOT DO THIS) ?
Did you open the drive lid ? (DO NOT DO THIS AS WELL)...
Etc .. Etc ...
Depending on the answers / problems the price will not be the same.
If you erase files and you didn't write anything else to the drive it might be easy to recover data with something like R-Studio as long as you didn't write anything else to the same partition over-writing the old data (on this case is un-recoverable).
If the drive stop working it can be many things like firmware issue, damaged head(s)/pre-amp, or even PCB ...
Did the drive fall on the ground ? Did it fall while it was working ? Etc ...
Author:  Iurii [ January 28th, 2019, 13:33 ]
Try to use Recuva :) It is free. Just connect to computer and run software.
Really, please provide more information and you will get better recommendation.
Author:  LarrySabo [ January 28th, 2019, 13:46 ]
HaQue wrote:
$985.72
:lol: :lol: :lol:
http://www.phpbb.com/
