 Post subject: WD HGST WD10SMZW WD10SDZW HTS541010B7E610 800066 unlock
PostPosted: January 10th, 2019, 6:58
please note you still need firmware tools. won't work with desktop only.
PCB to unlock firmware access for the following models :
HGST HTS541010B7E610 PCB 2060-800066
WD WD10SMZW-11Y0TS0 PCB 2060-800069
WD WD10SDZW-11UMGS0 PCB 2060-800069
USD $300 include shipping to most country.
This is one data recovery PCB specially designed to recover lost data from new WD hard drives with PCB number 2060-800066 (SATA) and 2060-800069 (USB). These drives have main chip lock and it’s not possible to read or write the ROM and access to SA by any firmware repair tools.
Now it is possible to recover these drives!
Whether it is 2060-800066 sata PCB or 2060-800069 USB PCB, users can use this data recovery PCB for data recovery purpose.
To use this data recovery PCB, users just need to solder the patient ROM chip off and solder the patient ROM chip on to the donor data recovery PCB and then install the data recovery PCB.
After above PCB and ROM swap, users can access to ROM and SA and repair the firmware corruptions.
Users can use this same data recovery PCB to fix multiple 2060-800066 or 2060-800069 data recovery cases, it depends on users’ chip soldering skills.
This unit is sold "AS IS" for parts or repair, and without any warranty.
will only sign your userID on the PCB and record a video of it accessing the firmware via PC3000.
 Post subject: Re: WD HGST WD10SMZW WD10SDZW HTS541010B7E610 800066 unlock
PostPosted: January 10th, 2019, 10:26
So you managed to find the unnecessary C.?
Donordrives was 380$ then after less than a month
DFL 350$ then now
You 300$
few days more probably then.... who knows
PostPosted: January 10th, 2019, 15:44
Cool ! :D
