 Post subject: PC3000 Flash Сircuit Board Adapter without soldering - READY
PostPosted: July 17th, 2019, 1:24
This adapter is designed for without soldering NAND-chips in various form factors and connecting them to PC-3000 Flash Reader (Ver. 3 or 4). The new Multiboard Adapter supports a broader range of microchips. The device consists of a main Multiboard adapter and replaceable modules: Monolith, LGA-52/TSOP-48 and BGA-152/VBGA-100. This approach allows to quickly switch between tasks and without solder microchips without the risk of damaging the adapter by heat. It is much easier to solder on a small monolith module, which also has higher interference immunity and data reading stability. The Multiboard Adapter enables you to cut costs on each monolith case due to cheapness, convenience and stable reading quality of replaceable modules, saving time and increasing return on investment.
More info available at 49335007@qq.com
Skype : 13378120549
