Hello guys,
We are working hard every day to make your work DR work faster and easier - we are not sleeping in holiday season
Today we are back with pack of new products
Finally we can announce that NEW monolith MR UFD adapters are READY !
* Links to products, movies you will find at bottom
- Monolithic UFD flash drive MR UP06 NAND adapter for Samsung FIT DUO BAR
- Monolithic UFD flash drive MR UP05 NAND adapter for Samsung FIT DUO BAR
- Fully configurable MR TSOP48 Wide adapter
Let's start with MR UP06
Support Samsung flash drive FIT, DUO, BAR - model 2020 version 32GB
Samsung flash drive where you can find this monolithic NAND memory:
MR UP05Photos of the adapter:
Support Samsung flash drive FIT, DUO, BAR - model 2020 version 64GB, 128GB, 256GB
For those of you who need 2 pcs set it's ALSO ready
MR TSOp48 WIDEPhoto of adapter:
Photo of adapter with mounted socket for 8 bit readout:
Pictures of the adapter with individual configuration of connections for TSOp pins (configurable via DIP Switch to ground or power supply):
------------------------------------------------------------Link to shop with MR UP06 -
https://multi-com.eu/shrt-ESIiqK2qcLink to shop with MR UP06 -
https://multi-com.eu/shrt-lbLe5x4XPLink to shop with MR UP06/UP05 set -
https://multi-com.eu/shrt-CUtajzEDWLink to shop with MR TSOP48 WIDE -
https://multi-com.eu/shrt-4yiZgkxSLink to YouTube video from connection of UP06 -
https://www.youtube.com/watch?v=P2fPEAse_mgLink to YouTube video from connection of UP05 -
https://www.youtube.com/watch?v=N74pxuCVltQ------------------------------------------------------------P.S#1
Full range of ALL available models, supported cards, movies you can see at
https://multi-recovery.comMore about our previous projects you can read at:
- eMMC/eMCP NAND adapters -
https://forum.hddguru.com/viewtopic.php?f=15&t=37381- microSD NAND adapters -
https://forum.hddguru.com/viewtopic.php?f=15&t=35872- microSD NAND VIAS adapters -
https://forum.hddguru.com/viewtopic.php?f=15&t=38543- SD NAND adapters -
https://forum.hddguru.com/viewtopic.php?f=15&t=38862P.S#2
Companies interested in reselling contact directly to
biuro@multi-com.pl for quotes.
