 Post subject: 40Gb ATMR NVRAM and other problem?
PostPosted: December 13th, 2007, 13:13
Hi all,
I'm running out of ideas with this one....
40Gb ATMR
P/N 08K0852
MLC: H69421
Dell P/N 0C2180
Initially it did not spin up, went straight to "safe mode"
On investigation I saw that the first two bytes of the NVRAM had been set to "00 00", which is clearly wrong. I change back to the usual "44 41", now it spins but clicks.
So I swap PCB with one of same f/w version, it spins and comes "DRDY DSC" but cannot ID the model, or read anything from SA.
I ordered in an exact duplicate donor (same model, date, p/n, MLC - Everything, even serial is very close), still same.
Is there a way to hot swap these, I don't think there is?
Any ideas guys???
Cheers
Sean
 Post subject: Re: 40Gb ATMR NVRAM and other problem?
PostPosted: December 13th, 2007, 15:10
Oops, wrong forum. Sorry.
