harddrivespecialist wrote:
You should not use 2 drives on a same line.
I guess I didnt explain my self correctly; using the command line as well as idle and with the power from an external source such as a power supply (not the one that comes with the util) i can do the SELFSCAN since i believe is a process intrinsic of the HDD itself.
I just need the current cumpsumtion of the HDD while on Selfscan so that I dont overload the power suply that am using for this and some of the HDD cant finish the selfscan.
i hope this clarifys it.
