Forum rules
You may only create a new topic if you have more than 100 hard drives for sale. For other offers please use this forum: Buy&Sell parts, hard drives, etc
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Professional Hard Drive and PCB Supplier - Over 10k Driv
PostPosted: January 14th, 2013, 5:14
pcimage wrote:
I have relationship/affiliation with DD or SD.
You forgot a "no" :D
WD Trusted Partners
PostPosted: January 14th, 2013, 6:04
Thank You for the reply. The NVRAM corruption was confirmed by SD Support themselves. They suggested to go for a Donor. But even donor had corrupted Modules. What to do ????
PostPosted: January 14th, 2013, 16:02
Oops!
Yes of course, I have NO relationship/affililiation!! :oops:
PostPosted: January 14th, 2013, 16:06
Not quite sure how any damaged modules on the donor would affect it's ability to act as a donor for NVRAM rebuild, which is what I assume SD meant you to do.
For this you need (ideally) is a working donor of the same ROM version and head map, then use the NVRAM SA start search routine, it can take a couple of days or more.
PostPosted: March 7th, 2013, 17:16
I am sorry it took so long for reply, as I have been very busy lately and wasn't checking the forums. Which email did you send it to? We never ignore emails, even if they are ludicrous. I am not sure what might have happened there, and I apologize.
Generally, we offer following options:
1. You can return item for a full refund
2. We can provide PC3000 backup of firmware
3. Provide limited data recovery support to potentially help resolve the issue.
Unfortunately we do not have SalvationData products, so we wouldn't be able to send you the modules in that format. We check if hard drive works by reading / writing test. Logically speaking, if some modules didn't read, it means that they are useless for HDD operation, and should not even be a concern to your recovery project.
Please email me at dglushko@donordrives.com if you have any questions.
http://www.donordrives.com - HDD Donors, PCBs, and Data Recovery Tools.
