Atola Insight 3.3 has been released! Owners of Atola Insight 3.x and 2.x are welcomed to update their software. Here is the change log:
http://old-insight.atola.com/changelog.htmlChange logNew features- Automated sector analysis in Disk Editor and Imaging
- Ability to estimate used space on source media in Imaging
- SMART table of Source media is now automatically added to the report before and after imaging
- Deleted file recovery on NTFS partitions
- Alternate data stream recovery
- Better search, new filters, support for regular expressions in File recovery
- New menu "Device Features": Advanced power management, PUIS, Acoustic Management
- Case Management now supports printing of attached pictures
- Generate Bad Sector now allows custom data to be written into "bad" sectors
- Serial Terminal will now automatically recommend proper baud rate
- Before powering down a drive the unit will now put the drive into Standby mode to flush all buffers
- Seagate Terminal connection instructions are now embedded into the software
- Imaging, Media Scan: minimum scale reduced from 20ms to 5ms to accommodate faster drives
- Added detection of new SMART attributes
- Case description can now be longer than 255 characters
Optimizations- Many speed improvements in File recovery
- Speed improvements when printing out a case
Bug fixes- By-head imaging of 4K Seagate drives will now properly detect LBA ranges
- Many bugfixes and stability improvements in Automatic Diagnostics
- Many small bugfixes in all parts of the software
P.S. All new Insight 3.3 features will be added to our leading product Atola Insight Forensic 4.1.
Attachments: |
File comment: Deleted file recovery on NTFS partitions
File comment: Better search, new filters, support for regular expressions in File recovery
File comment: Automated sector analysis in Imaging
File comment: Ability to estimate used space on source media in Imaging
File comment: New menu "Device Features"
File comment: Generate Bad Sector now allows custom data to be written into "bad" sectors
