 Post subject: Atola Insight 3.3 release
PostPosted: July 25th, 2014, 3:33
Atola Insight 3.3 has been released! Owners of Atola Insight 3.x and 2.x are welcomed to update their software. Here is the change log: http://old-insight.atola.com/changelog.html
Change log
New features
  • Automated sector analysis in Disk Editor and Imaging
  • Ability to estimate used space on source media in Imaging
  • SMART table of Source media is now automatically added to the report before and after imaging
  • Deleted file recovery on NTFS partitions
  • Alternate data stream recovery
  • Better search, new filters, support for regular expressions in File recovery
  • New menu "Device Features": Advanced power management, PUIS, Acoustic Management
  • Case Management now supports printing of attached pictures
  • Generate Bad Sector now allows custom data to be written into "bad" sectors
  • Serial Terminal will now automatically recommend proper baud rate
  • Before powering down a drive the unit will now put the drive into Standby mode to flush all buffers
  • Seagate Terminal connection instructions are now embedded into the software
  • Imaging, Media Scan: minimum scale reduced from 20ms to 5ms to accommodate faster drives
  • Added detection of new SMART attributes
  • Case description can now be longer than 255 characters
Optimizations
  • Many speed improvements in File recovery
  • Speed improvements when printing out a case
Bug fixes
  • By-head imaging of 4K Seagate drives will now properly detect LBA ranges
  • Many bugfixes and stability improvements in Automatic Diagnostics
  • Many small bugfixes in all parts of the software
P.S. All new Insight 3.3 features will be added to our leading product Atola Insight Forensic 4.1.
File comment: Deleted file recovery on NTFS partitions
File comment: Better search, new filters, support for regular expressions in File recovery
File comment: Automated sector analysis in Imaging
File comment: Ability to estimate used space on source media in Imaging
File comment: New menu "Device Features"
File comment: Generate Bad Sector now allows custom data to be written into "bad" sectors
Vitaliy Mokosiy
CTO, Atola Technology
 Post subject: Re: Atola Insight 3.3 release
PostPosted: July 28th, 2014, 15:09
Thank you for the Shift+F2!!
