The SalvationData forum: Like watching chickens run around with their heads cut off...
ST3320613AS rev. zz7l
http://www.salvationdata.com/forum/topic1301.htmlPage 1 of 1ST3320613AS rev. zz7l
Posted: Mon Feb 08, 2010 1:21 pmby badgoes
hi
i have a big problem. my hdd doesn´t working.
With the software from seagate and in the bios the rev. nr zz7l and it have 0gb.
how can i solve the problem
pls help me on the drive are a many pic.
Re: ST3320613AS rev. zz7l
Posted: Tue Feb 09, 2010 11:17 amby annleflore
Can you post terminal log if not you will need to have the SD Doctor for Seagate to repair this problem with it.
Posted: Tue Feb 09, 2010 12:00 pmby SalvationDATA
yes,would you kindly make a screenshot of the cmd mode so that we can check with you.
Best Regards
SalvationDATA
Posted: Tue Feb 09, 2010 12:38 pmby badgoes
hi
what kind of pic would you have
with wich progamm ?
Posted: Tue Feb 09, 2010 12:44 pmby badgoes
wich cmd mode do you mean
and how can i go to there
Posted: Tue Feb 09, 2010 12:48 pmby badgoes
Best Regards
SalvationDATA
wich cmd mode do you mean ???
and thanks a lot for your help
Posted: Wed Feb 10, 2010 9:01 amby badgoes
how can i make the screenshots ??
and which cmd mode do you mean
Posted: Wed Feb 10, 2010 10:31 amby SalvationDATA
Dear Clients,
Just print the Screenshot button of your computer,it is ok.
Or maybe you can copy the terminal mode(cmd mode) details in a txt file and send to us.
Best regards
SalvationDATA Team
Posted: Wed Feb 10, 2010 11:58 amby annleflore
Do you have a HD Doctor for Seagate??
If not that is the reason you do not understand what we are asking of you.
