 Post subject: Auto Repair on SD Tool
PostPosted: December 11th, 2013, 12:57
Hello
Quick question what does exactly the Auto repair option does on WD drive? have you ever done that and then the WD drive starts to a BSY state?
 Post subject: Re: Auto Repair on SD Tool
PostPosted: December 11th, 2013, 16:32
LoboX wrote:
Hello
It's the same with the repair option on WDR.
If you "repair" on a wrong drive / pcb and then flash that to ROM chip then ROM will be damaged and drive will be BSY because of damaged ROM.
Only way to fix is with external programmer or JTAG if ROM is embeded on MCU (or with other less-know ways or by populating ROM chip on Masked Rom PCB etc ...)
PostPosted: December 11th, 2013, 17:05
Thank You Spildit.
PostPosted: February 4th, 2014, 3:59
You can try find donor and try ''Hot Swap'' PCB. Sometimes it's work.
