 Post subject: Toshiba hdd get ready but not detect
PostPosted: April 11th, 2015, 4:06
I have a Toshiba 500GB MK5055GSXN, when connect to DC goes Ready but when I try, for example, read LBA it becomes blocked.
On HD Doctor becomes Ready as well but when try to Load from HDD becomes Very Busy and no answer.
No answer either from Terminal Mode (got just a strong dot) ...
Any ideas?
The disk was not dropped, stopped working sudently ....
Expect, the Unexpected
 Post subject: Re: Toshiba hdd get ready but not detect
PostPosted: April 11th, 2015, 4:28
Could be a suspect head or a firmware issue.
Dunno about salvation, but in pc3k one can read LBA via the utility (using a software translator).
PostPosted: April 11th, 2015, 4:43
will be solve but keep it powerd
after 5 min
will be ready
get id and goto translator regeneration and clear g list
https://www.facebook.com/datarecoveryegypt
PostPosted: April 11th, 2015, 5:40
after 5 min
will be ready
thanks islamm3rouf and pcimage
I keep it powerd 5 min afther that, when I try to Load from HDD, it's give me the same Very Busy and I conn't get id
PostPosted: April 12th, 2015, 1:28
the problem solved, and I start restore files, but with some block sectors
I appreciate your cooperation in this
PostPosted: April 12th, 2015, 11:35
So ...
How did you solve the problem ?
Mind to share ?
Thanks.
PostPosted: April 13th, 2015, 4:00
I connect HDD with HD doctor for toshiba and try to get id, it give me "very busy"
after a while "20 min" it turn to ready and then connect Data compass and open HDD from HD doctor for toshiba it's give me the partitions.
PostPosted: April 13th, 2015, 4:48
Ok. Thanks.
