 Post subject: Toshiba HDD for DR
PostPosted: March 7th, 2016, 5:08
I can't reach to userdata in Toshiba HDD 120 GB, it's Identify normally without any abnormal voice,
and it recognize all patameter correctly
and I make Backup for SA successfully
But when I try to access userdata, the HDD failed to read any sector
So, I need your help to specify the problme and solve it in order to DR.
I'm looking for your replies.
Expect, the Unexpected
 Post subject: Re: Toshiba HDD for DR
PostPosted: March 7th, 2016, 6:20
probably G-List try software translator
PostPosted: March 7th, 2016, 7:00
i haven't used HD Doctor for Toshiba, i don't think it has software translator option!
Data Recovery Pakistan
PostPosted: March 7th, 2016, 7:07
I haven't used HD doctor at all ;)
PostPosted: March 7th, 2016, 7:08
I got the same issue please help
PostPosted: March 7th, 2016, 7:17
I understand you have access to PC3K
try software translator (PC3K supports it)
PostPosted: March 7th, 2016, 7:27
we have pc3k express edition, really a tool to invest.
i also have SD tools WD+Seagate but not using them from last 2 years.
PostPosted: March 7th, 2016, 7:36
I tried to make that, But without any result
HD doctor for Toshoba has this option, But I'm afraid it's don't send the instruction correctly to HDD
PostPosted: March 7th, 2016, 7:40
like I said I haven't used HD doctor, but it's a different between regenerate translator and software translator
PostPosted: March 7th, 2016, 8:02
unfortuntly, I don't have PC3K.
I also noted that when I tried to read any sector the head make abnormal sound "try to read this sector"
I record this sound, and put it in attachment.
REC011.rar [339.49 KiB]
Downloaded 666 times
PostPosted: March 7th, 2016, 11:24
It's almost certainly what everyone is telling you, G-list damage. SD appears to only have the option to clear the G-list which will fail nine out of ten times. The only option is to use a software translator, which I'm pretty sure Salvation Data doesn't support. You'll need to get the drive to someone with proper tools (AKA PC-3000).
PostPosted: March 8th, 2016, 2:07
Thank you very much for your thoughts, I'll be find someone who have PC-3000
OR I'm thinking to buy new one because SD tools become expired :(
PostPosted: May 2nd, 2016, 2:28
update
I found the probleme for this HDD, I wana to share it!
The probleme is in a HEAD, I found H0 is damage, and H1 is still alive
So I make Image with selective head, it take 1 week, afterthat I'll make headswap from donor :)
PostPosted: May 3rd, 2016, 10:12
:D Nice trying. Clicking sound is quite aloud. Once you got that sound, no power connection any more.
PostPosted: May 5th, 2016, 8:46
I make Headswap for this HDD and I extract 100% from data :)
Thank you for all guys try to help me in this
Regards,,
