 Post subject: Seagate Classic and F3 Arch Case Studies
PostPosted: February 2nd, 2019, 22:54
Here is a collection of different case studies for the Seagate Classic and F3 Arch Hard Drives. There are over 100 different case studies for the different model hard drives. This is a work in progress book that has been created and more case studies will be added and the information updated. Each time I add new case studies and update the book it will be possible to receive a new copy of the updated book. This offer will be valid for 1 year from the date it has been downloaded. If you're interested in downloading your copy please visit this link https://9to5workonline.com/ebook-downloads/.
You can contact me at 9to5workonline@gmail.com.
You can request a TOC by sending me an email.
You will find over 100 different case studies for the Seagate hard drive families in this book. It is a collection of case studies I have been working on over the years and have finally compiled all the information in one place to make it easy to identify a problem and find a solution to repair the hard drive. I won't guarantee that all my case studies will repair all your problems. You still need to diagnose the hard drive to determine the real cause of the failure before attempting to repair the drive. Otherwise, this will cause damage to the hard drive and it might not be possible to retrieve your data.
Iorana Haraharaini
 Post subject: Re: Seagate Classic and F3 Arch Case Studies
PostPosted: February 18th, 2019, 23:02
Is rosewood family included in those cases ?
PostPosted: March 11th, 2019, 13:56
Yes - I can send you a TOC if you contact me on the email address I provided here.
I have just updated the book and added a lot more case studies to the book. The first revision has been completed.
Iorana Haraharaini
PostPosted: March 13th, 2019, 23:29
The manual has been updated and revised. Furthermore, I have created a small PDF file with 2 case studies you can have. If you are interested send your request by email. The email address is listed here in this topic. Thanks. Please don't send PM. I am rather busy these days and it takes me too long to answer them. Thanks.
Iorana Haraharaini
PostPosted: April 11th, 2019, 18:52
A second update has been added to the manual. I add more case studies, information on how to easily find the preamp in F3 Arch hard drives and a large DB file to help people find donor hard drives using the information from the head map, type of head and preamp. The manual is now 400 pages and more updates will be released again.
I have sent out all the new manuals and if anyone has an issue opening up the PDF files I sent let me know. Thanks.
Iorana Haraharaini
PostPosted: April 11th, 2019, 22:26
I had a person say the email address was not working. I checked it and it is fine. I did notice there is a period at the end of this and if you copy and paste this in - it will not work. Try using this one
There is no period a the end of the email.
Iorana Haraharaini
