Primary role: Electronic repair ... with a side of D.R. ability being icing on the cake.
Read schematics (not needing to by deductive logic or familiarity is even better) Proficient at SMT rework (incl. BGA & MICRO soldering - iPhone sized packages) You're organized such that others can pick up where you leave off Excellent memory (to put things back together as you took them apart). Rarely if ever make something worse - and recognize the possibility before you do. In those events where you may make things worse, you get client-permission, first.
If you're already familiar with macs, excellent.
If you're a good communicator, but don't speak english excellent, that's okay. We may work to understand each other... which is all that matters, as I then can explain it to the client.
If you have the above skills and talents, and have D.R. skills, and work at an affordable price - I just hope you live close, because you'll be hired!
Please contact me asap. Thank you!
