 Post subject: FW needed for WD1200BEVS-22RST0
PostPosted: September 8th, 2014, 10:09
I need FW for WD1200BEVS-22RST0 ,Family STG_ARIS and microcode is 000900BC.
Thanx
 Post subject: Re: FW needed for WD1200BEVS-22RST0
PostPosted: September 8th, 2014, 14:45
Here you go.
WDC WD1200BEVS-22RST0-04.01G04-WD-WXEZ07Y76133-96-690-900BC-Y.7z [2.09 MiB]
Downloaded 468 times
ACELab partner
PostPosted: September 9th, 2014, 6:46
Thanx a lot.
PostPosted: September 9th, 2014, 9:16
Worked?
ACELab partner
PostPosted: September 11th, 2014, 9:12
No. As I tried to write the ROM from this FW, It flashes the warning of error in ROM chip.I tried with 2 PCBs, but same message.My disk is not getting detected so I thought of writing ROM and other mods from your FW and then use original mods. But I failed .
Thanx a lot for support.
