 Post subject: HDD brick thanks to DFLWD...
PostPosted: May 5th, 2016, 21:49
To any kind soul that can help me repair the 4 HDD that is bricked...
I am a total newbie in this software, but I tried to read the ROM of the DFL tool on 4 western digital hard disk and the device said "ROM read success", so when I tried to write the ROM that I have just read out from the tool, I was being prompt with "ROM deep test error" (or something like that) and something about the "ROM being of a different length , would you like to force write" and I just ignored the warning and proceed to write the ROM. Now whenever I plug the HDD into the DFL tool, the 2 lights that are flashing are "DRD" and "ERR", the HDD is not even spinning anymore, please help SOS...
 Post subject: Re: HDD brick thanks to DFLWD...
PostPosted: May 5th, 2016, 23:00
Q: why have you tried to read and write in the first place ?
Q: what's the initial problem with the drive ?
Q: do you have any other tool beside DFL ? (PC3K, external programmer)
Q: can DFL access the PCB using terminal ?
Q: would you mind upload the ROM here ?
PostPosted: May 5th, 2016, 23:22
If drives are WD you can do a hotswap and rebuild ROM from SA. Look in DFL forum, there should be a manual how to do that. Do not try that on client drives but two known fully working ones for practice first.
Do not ignore warnings in DR-tools, most time they are right and you can trash a drive with them fast (ie defect list erase, ...).
Best regards,
Daten-Engel Datenrettung (Germany)
http://www.030-datenrettung.de
PostPosted: May 6th, 2016, 14:18
Did you read DLF WDII manual before you start bricking hard drives?
What was problem with those WD's.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: May 8th, 2016, 7:34
I would start to check if the WD drives that you have bricked have external ROM and if so you can use external programmer to write the ROM that you saved back to it.
Do you have something like WD-UCommand tool ? - http://www.hddoracle.com/viewtopic.php?f=22&t=217 Or even better something like PC-3000 ? If so you can write wrom back by TTL. I don't know if you can do that using DFL but i think not.
Why did you READ the rom and then WRITE IT BACK ? Did you write back the same ROM file created by the READ ? If so then DFL messed it up somehow. It shouldn't happen. If you read the ROM and then you write it (the same rom) then there shouldn't be any change in drive behaviour.
Maybe you need better tools ? Maybe there is a bug on DFL ?
PostPosted: May 8th, 2016, 21:04
The WD HDD did not have any problem at the start until I tried writing its original ROM back to it.
ROM_WDC WD5000LPCX-00VHAT0.bin.txt [256 KiB]
Downloaded 797 times
ROM_WDC WD2003FZEX-00Z4SA0.bin.txt [1 MiB]
Downloaded 809 times
PostPosted: May 8th, 2016, 22:45
I really don't get it, if the drive didn't have any problem in the first place, why would you try to rewrite the ROM
I really hope it doesn't belong to a client
Regardless what is the 2 files (I.e. which one is the problematic) ?
PostPosted: May 9th, 2016, 2:42
Both ROM are problematic just from different HDD. I was just trying to explore the different features of the software.
PostPosted: May 9th, 2016, 3:54
I can't check your ROM now, but This ROM is the same ver. as your ROM_WDC WD5000LPCX-00VHAT0.bin.txt just transfer the adaptives
the question is if you have access to drive to flash another ROM I.e. using TTL or external programmer.
Regarding the other one - like I said - I can't check it now, and I wasn't able to find it either.
PostPosted: May 9th, 2016, 11:03
The code sections of each ROM are OK.
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    PCMBLock       PCMBlk CS
Start  ID CS   Start - End     Exp/Act
00000  5A CD   00100 - 021EF  8F7D 8F7D   OK
00020  01 7E   021F0 - 04C18    4C   4C   OK
00040  02 D7   04C19 - 0BFB5    59   59   OK
00060  03 02   0BFB6 - 0C8CA    ED   ED   OK
00080  04 08   0C8CB - 0CAB7    CA   CA   OK
000A0  05 39   0CAB8 - 0CCC0    66   66   OK
000C0  06 73   0CCC1 - 1F325    D9   D9   OK
000E0  07 66   1F326 - 3CF3A    FF   FF   OK
00000  5A 95   00020 - 00FB1  E400 E400   OK
01000  01 6A   01120 - 03300    DE   DE   OK
01020  02 30   03301 - 03815    FB   FB   OK
01040  03 DF   03816 - 0C036    B1   B1   OK
01060  04 1B   0C037 - 0C6E3    57   57   OK
01080  05 52   0C6E4 - 0C8E4    B0   B0   OK
010A0  06 C6   0C8E5 - 0CAE9    15   15   OK
010C0  07 E4   0CAEA - 25166    39   39   OK
010E0  08 06   25167 - 4188B    A7   A7   OK
81000  01 6A   81120 - 83300    DE   DE   OK
81020  02 30   83301 - 83815    FB   FB   OK
81040  03 DB   83816 - 8C02E    83   83   OK
81060  04 0B   8C02F - 8C6D7    DB   DB   OK
81080  05 46   8C6D8 - 8C8D8    0A   0A   OK
810A0  06 BA   8C8D9 - 8CADD    6F   6F   OK
810C0  07 D4   8CADE - A5156    E1   E1   OK
810E0  08 F6   A5157 - C187B    A7   A7   OK
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
PostPosted: May 9th, 2016, 18:53
I would say that either the user have done something wrong and flashed the wrong ROM file to the wrong PCB or DFL have some issue/bug and wrote incorrect data to ROM chip/MCU embeded ROM by VSC bricking the PCB.
Now the question is how to fix it!
If the PCB have external ROM chip you can re-programm the backup back to the chip with something like this :
http://www.hddoracle.com/viewtopic.php?f=117&t=865
If ROM is embeded on MCU you can use something like this :
Or you can use PC-3000 if you have it ....
