 Post subject: DFL-SRP without DFL-URE?
PostPosted: July 19th, 2016, 12:09
Hi
I am new here.
I am preparing for a DR business and thinking what equipment and tools I will buy.
Probably this is from my lack but I am just wondering if I can start with DFL-SRP (without DFL-URE)? I guess that I can get external hard disks, flash drives connected to DFL-SRP through usb to sata adapters and fix them as I do with DFL-URE ? I have no idea if there is any big difference between DFL-SRP and DFL-URE. Any advice and comments would be much appreciated.
Thanks.
CK
 Post subject: Re: DFL-SRP without DFL-URE?
PostPosted: August 31st, 2016, 22:38
SRP is enough for starting ur business. the good usb drives that u can directly connect to the pc. and can use the SRP to recover;if the usb drives that have fw issue. just find the compatible pcb to repalce and connect to the SRP. if u have extra money, you can buy URE
