@fzabkar; Checked out Niagara and while I'm pretty sure I found the right section to set link speed, it seems to have failed:
CMD: A1 06 20 54 02 00 C7 A9 00 8F 00 00
FE SC LL LM LH DH CM
ATA: 54 02 00 C7 A9 00 8F
Error (0 ms) At 08:56:52 07/15/18
<E> Check Condition:
Info: Command Returned 0 bytes
70 00 0B 00 00 00 00 0A 00 00 00 00 00 00 00 00
00 00
Translation: Aborted Command. No Additional Sense Code.
For reference, after opening Niagara (spti driver detected my drives) I ensured only the target device was selected, then went to ATA Tools > Set Features > Vendor Unique Features > 0x54: Set SATA Speed Limit > 0x2
@Spildit; Primary goal is to set link speed to 3Gb/s. I was finally able to get the drive to show up to the feature tool from hgst, but it claimed the drive didn't support changing link speed.
So as a note, this drive came out of a NetApp appliance and was previously flashed with NetApp's custom firmware. What all that changes, I'm unsure, but that's the main reason for trying to find stock firmware. I'm not sure I can set the link speed until I've gotten rid of this garbage NetApp Firmware.
Thanks!
