 Post subject: seagate desktop hdd
PostPosted: February 28th, 2017, 7:48
does anyone know where i can get a pcb circuit board for my seagate 3tb hdd
MODEL ST3000DM001
FW CC25
would prefere to get one from somewhere in the uk as i dont trust getting things from outside europe
thanks
glynn
 Post subject: Re: seagate desktop hdd
PostPosted: February 28th, 2017, 10:34
Not to be the bearer of bad news, but I'm 100% certain that your problem has nothing to do with the PCB. In the 200-300 or so of those drives that I've done recoveries on there hasn't been a single one that was a failed PCB. That model has extremely weak read/write heads and known firmware glitches that'll make it stop working. They actually had so many fail they are in a class action suit in the USA now: https://www.extremetech.com/extreme/222 ... lure-rates
If the drive is clicking and spinning down, you can bet it's failed read/write heads. If it sounds to be spinning normally, it's probably an issue with the media cache which will need to be disabled in the firmware code. In either event you'll need professional recovery. Since you are in the UK I'd recommend you go to http://pcimage.co.uk
