 Post subject: Samsung 860 EVO SSD 1 TB over voltage repair
PostPosted: August 24th, 2020, 15:23
Hi Folks,
I made the mistake of swapping power supplies in two of my pc's, a evga 850w with a evga 1000w, and switched all cables except sata. The result overvolted 2 of my 860 evo 1 tb ssd's. Yes now I know I should have paid attention to the manual to always use original cables, but I thought since same manufacturer it would be fine (it would be nice of evga to prevent future user error by changing their form factors for the differing cables). I have read a couple posts here of similar situation with 850 evo ssd where replacing the e-fuse with a STEF4S repaired the drive. I have been trying to identify the efuse on the 860 but the layout is a bit different from the 850. Any guidance is appreciated, I would like to get these drives operable again. Fortunately I had nearly all important files backed up in the cloud, but still some I would like to retrieve. I have a few STEF4S ic's already ordered if they turn out necessary.
I don't see any burn damage and there was no smoke nor smell, just the drives could not be recognized by bios. Thanks for your help.
 Post subject: Re: Samsung 860 EVO SSD 1 TB over voltage repair
PostPosted: August 24th, 2020, 20:30
Here it is:
You can bypass it with a wire link by connecting Vin to Vout, with caveats.
PostPosted: August 24th, 2020, 21:02
@fzabkar Thank you sir, I'll update with results.
PostPosted: August 25th, 2020, 0:21
Success! It wasn't easy to solder the wire, but at least there are 3 vins and 3 vouts. Thank you again fzabkar, many blessings to you in this life and the next.
Interesting, that the 2nd evo 860 drive I hotwired had a much different pcb layout but I was able to identify the efuse.
PostPosted: January 17th, 2021, 0:32
hi there, noob here, i have the same exact ssd, and the same problem, could you tell me witch pins on that chip to jump? (hot wire) thank you!
PostPosted: January 17th, 2021, 14:18
Find the datasheet for the STEF4S and the bridge the Vin and Vout pins, if there is no other damage.
http://www.hddoracle.com/viewtopic.php?f=100&t=1615&p=8872#p8872
PostPosted: February 4th, 2021, 17:25
Hi after all, i need a little help, i guess you can support me
I find this post very interesting, i have a samsung evo 860 250gb that stop to work from one day to another, the bios doesn´t recognise the ssd, i make some measures and i found many shorts in the board, i show you in the following images.
Please, i need to recover some important files, what can i do with this? do you think if i do the short on the STEF4S the unit come alive?
Thnks 4 all.
Users browsing this forum: Google Adsense [Bot] and 4 guests
