 Post subject: Samsung 860 EVO SSD 1 TB over voltage repair
PostPosted: August 24th, 2020, 15:23
Hi Folks,
I made the mistake of swapping power supplies in two of my pc's, a evga 850w with a evga 1000w, and switched all cables except sata. The result overvolted 2 of my 860 evo 1 tb ssd's. Yes now I know I should have paid attention to the manual to always use original cables, but I thought since same manufacturer it would be fine (it would be nice of evga to prevent future user error by changing their form factors for the differing cables). I have read a couple posts here of similar situation with 850 evo ssd where replacing the e-fuse with a STEF4S repaired the drive. I have been trying to identify the efuse on the 860 but the layout is a bit different from the 850. Any guidance is appreciated, I would like to get these drives operable again. Fortunately I had nearly all important files backed up in the cloud, but still some I would like to retrieve. I have a few STEF4S ic's already ordered if they turn out necessary.
I don't see any burn damage and there was no smoke nor smell, just the drives could not be recognized by bios. Thanks for your help.
 Post subject: Re: Samsung 860 EVO SSD 1 TB over voltage repair
PostPosted: August 24th, 2020, 20:30
Here it is:
You can bypass it with a wire link by connecting Vin to Vout, with caveats.
PostPosted: August 24th, 2020, 21:02
@fzabkar Thank you sir, I'll update with results.
PostPosted: August 25th, 2020, 0:21
Success! It wasn't easy to solder the wire, but at least there are 3 vins and 3 vouts. Thank you again fzabkar, many blessings to you in this life and the next.
Interesting, that the 2nd evo 860 drive I hotwired had a much different pcb layout but I was able to identify the efuse.
PostPosted: January 17th, 2021, 0:32
hi there, noob here, i have the same exact ssd, and the same problem, could you tell me witch pins on that chip to jump? (hot wire) thank you!
PostPosted: January 17th, 2021, 14:18
Find the datasheet for the STEF4S and the bridge the Vin and Vout pins, if there is no other damage.
http://www.hddoracle.com/viewtopic.php?f=100&t=1615&p=8872#p8872
PostPosted: February 4th, 2021, 17:25
Hi after all, i need a little help, i guess you can support me
I find this post very interesting, i have a samsung evo 860 250gb that stop to work from one day to another, the bios doesn´t recognise the ssd, i make some measures and i found many shorts in the board, i show you in the following images.
Please, i need to recover some important files, what can i do with this? do you think if i do the short on the STEF4S the unit come alive?
Thnks 4 all.
PostPosted: March 19th, 2021, 9:05
Well, if 2 capacitors at the output of the electronic fuse appear to be short circuited to ground, IMHO there are 3 possible scenarios:
* One of those capacutors may have an electrical breakdown (you can safely remove those capacitors and doublecheck if there is still electric cintinuity between ground and the output of the electronic fuse).
* If there is still zero resistance between the output pins of the electronic fuse and the ground we need to desolder the electronic fuse in order to continue our investigation. It is well possible the the short circuit is just inside the electronic fuse itself.
* If there is still zero resistance between the output pads of the electronic switch (on the PCB) and ground it means the short circuit is somewhere else. In this case bypassing the electronic switch with a jumper will not help.
