Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Forensic Image Hash
PostPosted: June 27th, 2018, 15:11
But ... even if on the fly it is faster, hashing what ? One sector a time ? One megabyte ? And do what with the hash(es) ? Store them alongside or just present to the user ?
Okay, you can keep running the calculations for the hash and keep feeding the bytes read to the polynomial calculation of your specific hash method. It would probably avoid some time at the end of the cloning to read the image and calculate the hash. But, would it enough to justify the increased complexity ?
PostPosted: June 27th, 2018, 15:25
THAT is the magic question :mrgreen:
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
PostPosted: June 27th, 2018, 15:31
Let me rephrase the magic question:
Would adding this feature to the pro version in any way help to sell HDDSuperClone? THAT is the real magic question that will drive whether or not I do it. Would the return be worth the effort? :?
PostPosted: June 27th, 2018, 15:41
I don't think so because the HDDSuperClone strong points is to be an alternative to hardware sollutions to clone BAD drives and the hashing would be a strong point to use when imaging GOOD DRIVES !!!
If you were to be using the tool to image a drive without a single bad sector hashing would be ok as you would read the sector and you would create the hash on the fly avoiding extra time to re-read sectors to re-calculate the hash.
This wouldn't apply to a tool made to recover data out of bad sectors.
HDDSuperTool strong point is to be able to extract "more data" out of damaged drive. And it doesn't make sense to compare hashes of images done by several tools as you would get a diferent hash even if just a single byte were to be diferent on the image. If your tool gets more data the hash would be diferent from the one generated by another tool as well.
This would only make sense for 100% working drives where you would image, copy the image over to another person and that person were to need to verify that the "image" were exactly the same as the one produced by you.
PostPosted: June 27th, 2018, 15:45
That would be better to the three people who asked for it to answer.
Just an opinion, but pc3k doesn´t have it. Maybe they considered and then decided to focus on the main purpose of fixing hard drives.
Maybe add an option to calculate a md5sum of the created image after done cloning ?
PostPosted: June 27th, 2018, 15:47
That would take a huge amount of time to re-process the image/clone and the user could just use any other tool available on the market to calculate the hash ...
PostPosted: June 27th, 2018, 16:07
Yeah, something like:
Type one of the following commands to hash the image on your own using built in Linux commands so I don't have to deal with it:
md5sum -b imagefilename
sha1sum -b imagefilename
:mrgreen:
PostPosted: June 27th, 2018, 16:12
Maybe I will get ambitious enough to go back through my emails and find them, and ask a few questions. Maybe...
PostPosted: June 27th, 2018, 16:20
:mrgreen:
Sounds nice !
:mrgreen: :mrgreen: :mrgreen:
This would only make sense to save time and in the context of 100% working drives without a single bad sector and hash on the fly (while reading to do the image).
PostPosted: May 10th, 2019, 18:17
Perhaps an option to calculate the checksum for each copied / recovered sector and store it in a text file would be more relevant to the original purpose of HDDSuperClone. With a complementary feature which would load the text file and verify each sector against the image / clone, making it easier to pinpoint the exact locations of modified sectors, if any. This should be a lot easier to implement than calculating a global checksum, as was requested. But the resulting text files would be huge : with one MD5 checksum per line and no other data, that would still make a 232GB file, even more with a more secure method... :shock: A cluster level calculation would make it a tad more manageable, but the program would need to determine the cluster size, which can be different for each partition on the same device. Or there could be some kind of on-the-fly compression.
As for getting requests outside the original scope of your "flagship" tool, I read somewhere that any software being developped for a sufficient amount of time always ends up being able to send e-mail messages, so be prepared ! :)
PostPosted: October 24th, 2019, 6:57
maximus wrote:
Let me rephrase the magic question: Would adding this feature to the pro version in any way help to sell HDDSuperClone?
No. I would not buy the pro-version just because of on-the-fly-hash. I would buy the pro version because of everything else (i.e. the software does a good job).
PostPosted: October 24th, 2019, 9:47
forensics don't necessarily need a hash in the form you are asking for.
it just needs an accepted documented process to show the chain of evidence.
You could probably find some smart assed defence "expert" to poke holes in the hashing method.
