 Post subject: WD drives and headparking
PostPosted: September 5th, 2020, 15:33
Hello.
I have received harddrives in the past by mail. Who were wrapped in a single layer of bubblewrap and put in a small brown box with no protection. Cringe. Harddisks worked fine. But a friend of mine dropped his western digital elements drive off a table about 4 ft after it was properly ejected and made no mechanical spinning sounds. I would guess the drive parked the heads properly. And although these drives are also surrounded by 4 thick pieces of rubber and encased within a plastic shell. The drive wouldnt turn on after. Why is this.
Do western digital drives have special protection like an extra latch that holds on to the HSA before first use?
Do western digital drives park their heads on or off the platters?
I have recorded the soft sound it makes when trying to turn it on. https://voca.ro/cvZ3t6RD6NN
What might have happened here?
 Post subject: Re: WD drives and headparking
PostPosted: September 5th, 2020, 15:36
I have seen some videos. And in case yhis is about stiction to the platters. Do you need to make a shim to keep the hsa heads seperated before moving then off the platters?
PostPosted: September 5th, 2020, 16:42
You keep running into these or what? Are you looking for anyone's approval do follow the example of the 'stook heads' video?
If the data is of any importance, you don't power it up again and send it to a lab.
PostPosted: September 6th, 2020, 14:26
+1000
Nope. But good idea :)
Modern drives park heads outside the platters, onto a ramp.
This is stiction 100%. Dropped WD drive with stiction, more often than not heads are affected by this too.
Users browsing this forum: No registered users and 32 guests
