hisham_munshar wrote:
I have a Toshiba 750GB MQ01ABD075 hard disk that clicking and needs head replacement
if it is suitable to transfer the heads from it to the patient one?
Most likely heads will fit, but this probability isn't 100% perfect - once we've had one, where everything except the S/N was the same, but heads didn't match.
But be prepared to a concentric scratch. If the drive is clicking and unable to id, then I'd say that probability of scratch is 95-98%. If it identifies, but one head isn't reading, then chances are lower, but still high.
The exclusions are drives, where heads got stuck and died because of that or just turned inside out / smashed.
