 Post subject: My hdd is dead (ST31000520AS)
PostPosted: December 16th, 2016, 7:01
Hi everyone! That is my firts time here. I´m computer fan.
I have a big problem with my seagate hdd (ST31000520AS). It is dead. Bios can´t recognize it. I try in other computer and same problem. The hdd noises are normal. It does not have the typical noise when it is a physical problem. What is the problem that you think it might be? Do you have any manual to remove the electronic board of this hdd? Perharps problem is file from e2prom. I don´t know. Please help!!
Thanks in advance ;)
 Post subject: Re: My hdd is dead (ST31000520AS)
PostPosted: December 16th, 2016, 7:34
I have photos and read from e2prom W25X40AL. If you need them I can upload. Just tell me. Thanks ;)
PostPosted: December 16th, 2016, 12:29
Do you have terminal ( TTL ) response?
If yes, print the results.
Regards.
Marcus
PostPosted: December 16th, 2016, 12:31
Do it in the Conventional hard drives, ok ?
PostPosted: December 18th, 2016, 14:27
Hello again. I dont have TTL. Can you recommend any?
here e2prom my hdd and photos.
File comment: e2prom from my hdd
W25X40AL_HDD.rar [67.46 KiB]
Downloaded 516 times
PostPosted: December 18th, 2016, 16:39
@alclot, you have posted your question to the wrong forum. It should be in "Convential hard drives". In any case there is no problem with your e2prom.
PostPosted: December 25th, 2016, 16:43
i do not know what is the reason to spam like this, who has something out of it. You will get better answer on regular group. Not on HddSurgery topics...
HddSurgery - Professional Data Recovery Tools
Users browsing this forum: MSN [Bot] and 1 guest
