 Post subject: Sandisk CF Card Ultra 32G (SDTNQGBMB-016G NAND)
PostPosted: March 20th, 2018, 18:06
Hi Forum,
I have a Sandisk Ultra 32G CF Card. It uses 2 SDTNQGBMB-016G NAND Chips.
The controllers seems to be defective, but I have good hope the NAND chips are not impacted.
The VNR Reader does not have the SDTNQGBMB-016G in its database.
If I use the settings from SDTNQCCMA-064G, it can read the ID, and I can see data in the dump viewer.
It does not read any ONFI Parameters however. (And since the device has a different capacity, I don't know what parameters (page/block/plane) will differ, but it can not be the same)
I can not find any datasheets of these chips. Is there anyone who has the correct parameters of this IC?
Next part;
The controller used in the CF card is a 20-82-00314-4 The VNR has a sandisk CF with the 20-82-00309-3 controller in its database.
Would those controllers be the same to decode? If not, does anyone have the correct decoding method for this card?
My first instinct would be to just try to find the same model of CF-card and transfer the NAND's, but I bought the VNR to not depend on that strategy :-)
Thank you !
File comment: Config
File comment: Read IDs
File comment: Sandisk Ultra 32GB Internals
File comment: Sandisk Ultra 32 GB
 Post subject: Re: Sandisk CF Card Ultra 32G (SDTNQGBMB-016G NAND)
PostPosted: March 21st, 2018, 12:42
Hello!
Send message to our support team, one of our engineers will help you identify the memory configuration.
Drop description about case here: suppport@rusolut.com
VISUAL NAND RECONSTRUCTOR. A big revolution in chip-off data recovery
PostPosted: March 22nd, 2018, 0:51
I a Not Sure Of This ,But Some of The Controllers i have come across in sandisk CF Cards Are SM Based .
PostPosted: March 22nd, 2018, 3:03
There is config for this ID:
Odzyskiwanie danych
PostPosted: March 22nd, 2018, 9:14
Hello once again!
We have this NAND chip in database. Configurations in VNR are stored by NAND ID number, instead of model.
The reason is simple: one NAND chip can be found in many packages(BGA, TSOP or monolithic etc.). Storing configs by models will results to many duplication.
Below is link to article from our website, where we describe reading process:
https://rusolut.com/direct-access-to-na ... xtraction/
PostPosted: March 22nd, 2018, 20:06
Thank you for the tip's and pointers.
I was indeed confused that the Chip ID was foud 3 times in the database. Therefore, I tought that the phisical form and type number of the chip was the most important, not the ID.
There are 3 entries in total. 2 entries in the database have the same parameters.
The "MonoSD" one does not seem to work, the reader goes in error state after reading the first few pages but the "monolith" one with different page size does read the first NAND chip.
Now trying to read the second chip. I had some difficulties reading the second chip on the first try, but lowering the voltage seems to pursuade the chip to read.
Kind regards,
Hans
PostPosted: March 23rd, 2018, 7:20
Well,
I am at learning stage Of VNR Myself And More Confused Then You Are .I have a SM2236 With 4 BGA-152 Chips and i Need To Try Reading Then With VNR .But I Am Presented With Options That are going above my head .I am gonna make a post here soon on that
PostPosted: March 28th, 2018, 11:22
the SM2236 are often joined by small join size (8 bytes or so), and some cases have join by byte.
Did you read chips for this case yet?
PostPosted: March 28th, 2018, 13:38
2236G will be joined by Qword (64 Bits/8bytes ) The interleave is usually 0246 / 1357 dump order if you read the chips using the order numbers on the PCB *KE 8)
PostPosted: March 29th, 2018, 13:29
Well,
I wonder Why We Say U51 Is The First Chip To Be Read ,Although U50 is The Smallest From U50 ,U51 ,U52 And U53 :mrgreen:
PostPosted: March 29th, 2018, 18:41
It is a type of standard component marking. U usually means IC. U4x could be one circuit function such as power chips U5x can be other functions such as memory, U1x might be controller... where the "x" is a number of the component It is a way of knowing which components belong to what circuit function.
PostPosted: March 30th, 2018, 13:29
Well,
I am absolutely clear on this ,My question was Why Read U51 As Chip 1 And U50 As Chip 2 .I have a Good Electronics Background Haque
PostPosted: April 1st, 2018, 5:22
Who said read u51 as chip 1?
I have always read lowest to highest..
PostPosted: April 2nd, 2018, 13:12
Sir ,
Since how much time are you doing NAND Chipoff :shock: . Please Have a Peek Here ,Specially on BGA NAND Chips -> http://flash-extractor.com/library/SM/SM2236/
PostPosted: April 2nd, 2018, 14:47
Amarbir[CDR-Labs] wrote:
Sir ,
You talk to one of the most experienced flash guy ;)
Odzyskiwanie danych
PostPosted: April 2nd, 2018, 15:22
Sir ,
Might Be ,
But even i am not wrong in my observation to the top stated facts ,I would really love a explanation
PostPosted: April 2nd, 2018, 20:38
The soft Center manual for reading chips is probably the only reference to a standardised way of doing it. It is just so everyone that uses SC tool is on the same page when reading chips for FE. It is not any industry standard or anything, just a guide for that tool.
What matters is finding the dump order, not really what order the chips are numbered. The only way this helps is reall prior experience on a certain device.
The jury is out on whether the PCB designers label their IC's in the same order that the firmware designers plan to use them, in relation to the order. My guess would be that it is a crap shoot
dont sweat the small stuff.
PostPosted: April 2nd, 2018, 21:26
Sir ,
IMHO Definitely before you
PostPosted: April 2nd, 2018, 21:53
most people link to the SC manual on chip order: http://flash-extractor.com/manual/chip_numbers/
but as I said, it is just what SC decided on and for that tool. as you can see the CF card goes 1,2,3,4 == U22,U23,U21,U24
So don't get hung up on PCB markings. As you can see here:
http://www.flash-extractor.com/library/SM/SM2236/SM2236G%20AC__2c_48_00_26__4x2
4 chips with 2 banks (crystals) each.
chip 1 (U22) = dumps 0,1
chip 2 (U23) = dumps 2,3
chip 3 (U21) = dumps 4,5
chip 4 (U24) = dumps 6,7
model states order of dumps to rebuild logical image is 4/0/2/6/5/1/3/7
so that is:
U21, crystal 1
U22, crystal 1
U23, crustal 1
U24, crystal 1
U21, crystal 2
U22, crystal 2
U23, crustal 2
U24, crystal 2
so it does work out to be PCB marking order.
In flash, you just have to do whatever works. Often you will get stuff that makes no sense at all.
PostPosted: April 3rd, 2018, 8:37
Sir ,
Well,
You Are Also Here And i Am Also Here For The Next Three Months You Wait And Watch .The Proper Explaination is Here -> viewtopic.php?p=257768#p257768 .Most of The Controllers Embed Thier Controller No in the NAND dumps ,So To Arrange Them In Order Its Necessary To check Them and Set The Order of The Dumps .I have a SM2236 Right Now and i Will Post The Details Soon Incase Someone Does Not Know .I had Some of The Initial NAND Tools From Acelab but never ventured deep into flash ,Things Are Very Different Now Buddy .In My Case i Have a Chip With 4 Parts Each ,Hence 16 Parts In Total :D
