 Post subject: Kingston USB recovery Rusolut
PostPosted: July 19th, 2018, 7:00
I have a problem recovering files from a Kingston USB pendrive.
Memory chip is a:
Hynix
FT64G08UCH1-09
ADDE94DA74
Controller is a Phison ps225
I had the training from rusolut but forgot everything. Does anybody have a walk through for that one. At the moment ECC caused me headaches it is 77 bits but software complains about that also I do not think this one is xor and just an inversion. Any input welcome.
 Post subject: Re: Kingston USB recovery Rusolut
PostPosted: July 20th, 2018, 5:15
Memory chip is a:
Hynix
FT64G08UCH1-09
ADDE94DA74
Hi Nico,
drop message to support@rusolut.com or chris@rusolut.com. I will help with this case and try to recall you basics.
PostPosted: August 20th, 2018, 3:35
This will require XOR (bitmap view should show this). Also for ECC, if I remember right the first SA is larger than others so if this is not defined right ECC wont fit. Maybe this is whats wrong?
