Pinouts of monolithic flash devices
http://forum.hddguru.com/viewtopic.php?f=27&t=30084
Author:  Sasha Sheremetov [ December 4th, 2014, 10:45 ]
Post subject:  Pinouts of monolithic flash devices
Every update we add pinouts of monolithiс flash devices into built-in database of Visual Nand Reconstructor. You can find them in Trusted Devices database. Just filter list by device type and check images of devices to find the one that looks same as yours.
Author:  pcimage [ December 4th, 2014, 14:08 ]
Post subject:  Re: Pinouts of monolithic flash devices
Now, that is neat :-)
Author:  lcoughey [ December 4th, 2014, 14:40 ]
Would you expect anything less from Sasha?
Author:  digisupport [ December 4th, 2014, 15:04 ]
Nice Sasha :)
Author:  Sasha Sheremetov [ December 5th, 2014, 12:18 ]
There's a special adapter in Visual Nand Reconstructor kit, that used for monolithic chip soldering (using thin copper wires).
The device must be glued (glue/luquid nails/double sided sticky tape) at the middle of adapter. All signal markings on pinout and adapter are same, so it's easy to solder it properly and not to mix it up.
We use one of the best possible PCB materials, however sometimes golden pads may get damaged (due to overheating). You can solder chip directly to the needles of connector (check picture).
In nearest time we'll make a lot of spare monolith adapters with affordable price (sold separately), so you can use it as expendable material, no need to remove device every time(it's pretty jewelery job that everyone wants to keep :)).
Author:  labtech [ December 5th, 2014, 12:21 ]
I like - on my Santa wish list...
Author:  HaQue [ December 5th, 2014, 18:17 ]
nice adapters, yes once I have soldered on I don't like removing monolith ;-)
Author:  positivebit [ December 16th, 2014, 5:07 ]
nice tool in the last week i recovered 2 difficoult cases, one with only one nand OK (other nand coudn't even ID) and the adapters are really well built!
