 Post subject: How Do I Import PC3000 Flash Dump?
PostPosted: April 4th, 2016, 13:19
I have a couple of cases which cannot be solved by PC3000 Flash which I would like to try on Rusolut (just renewed my support). For efficiency is there a way to import a dump from PC3000 Flash?
 Post subject: Re: How Do I Import PC3000 Flash Dump?
PostPosted: April 4th, 2016, 13:22
Excuse My Eagerness To Know ? ,
What Version Reader In Acelab And Software you Are Using ,I Plan To Get Infact Update My Pc 3000 Flash Before i Buy Rusolut And Your Comment Worries Me :(
PostPosted: April 4th, 2016, 13:28
I have a couple of cases, but the XOR function is not always available on every software (PC3K, VNR FE etc). So swapping from one to the other can work. I have the latest PC3000 Flash version, but that doesn't really help with some cases.
PostPosted: April 4th, 2016, 13:35
Ok ,
I Got It Now After PC3k Update I am Planning To Get VNR Also
PostPosted: April 4th, 2016, 17:24
It is really easy. Do you know function Plug and Play? :D You can do it in few different ways:
1. Grab dumps, move to VNR window and drop it. Thats all.
2. Open images from top menu.
3. From left objects take Physical image and move to main window, than on Parameters click on icon on right side of "File", select dump you want to import.
4. Take project case file *.case, edit and add file to case (it is like programming for masochist - but it can be done) :)
Odzyskiwanie danych
PostPosted: April 5th, 2016, 19:13
