HDD GURU FORUMS
http://forum.hddguru.com/
pin out monolithic pendrive
http://forum.hddguru.com/viewtopic.php?f=27&t=34718
Page 1 of 1
Author:  alemmat [ December 26th, 2016, 9:57 ]
Post subject:  pin out monolithic pendrive
Hi everybody how are you?
Happy holidays
i need the pin out for a monolithic pendrive, i find a very similar pin out in the aclaboratory solbase (UFD Type 30), but every time i try to read the id each crytal (the vnr reader detect 4) give me a different id, like 002fa00a.
When i was welding the pen drive to the monothic adapter, i tested each contact to see if i have a short circuit.
if some one have a similar pin out i have very grateful
my best regards and happy holidays
Author:  Sasha Sheremetov [ January 13th, 2017, 9:25 ]
Post subject:  Re: pin out monolithic pendrive
We will add this one most likely in coming update.
Author:  Amarbir[CDR-Labs] [ January 16th, 2017, 13:27 ]
i hope the testing has not shorted anything ,Might be special multimeters that use low voltage like 0.25 volts to test can be used
Author:  alemmat [ January 19th, 2017, 14:30 ]
Thanks Sasha, when you belive you do the release
Author:  Sasha Sheremetov [ October 18th, 2017, 18:36 ]
I know it's kinda late, anyway we added this pinout to database in one of recent updates here.
http://www.phpbb.com/
